Feb-08-2014 06:41 AM
Feb-13-2014 12:19 PM
Feb-13-2014 07:38 AM
palehorse89 wrote:
The one thing I am having trouble with is finding one that will work , I have talked to a rep. at Curt Mfg. , not to much help. My receiver now is bolted on, by design, tight to the frame rails where it bolts on with no drop, my bolt holes on each frame rail are 6" apart, 3 on each rail. Can someone with a newer Coach(Newmar) with a class 4 or 5 hitch tell me the brand of hitch and the model number. I would like to find a close replacement in height as the receiver that is on there now comes through the rear flap and I don't want to have to change the flap if I don't have to.
Feb-13-2014 01:50 AM
Feb-11-2014 01:40 PM
Feb-10-2014 07:30 PM
JimM68 wrote:
You're 10k receiver won't be bolted on, it will be welded on, most likely a the 5k receiver is too. Take it to a truck frame shop, they will know how to handle it.
Feb-10-2014 05:22 PM
wa8yxm wrote:
If the chassis can tow 10K, then upgrade, and ask the manufacturer why they did not put a 10K hitch on it to start with.
One thought... Naa. you will report if this is the case you will report if this is the case (Receiver size).
Even with the enclosed trailer, you won't be that close to max so GO FOR IT.
Feb-10-2014 04:09 AM
Feb-09-2014 04:02 PM
Feb-09-2014 06:13 AM
Feb-09-2014 05:45 AM
wa8yxm wrote:
I think I answered this elsewhere.. You said the chassis has a 10,000 CGVW rating (you may have put it in a different order) This means the Motor home and trailer, combined, loaded, must not weigh more than 10,000 pounds.
How you can do that and still overload a 5,000 pound receiver I do not know, I know I can't and my CGVW rating is 26,000.
Or did you mis-type.
Feb-09-2014 02:17 AM
Feb-08-2014 10:01 PM
Feb-08-2014 09:11 PM
Feb-08-2014 08:49 PM
Feb-08-2014 03:13 PM
My 5,000# receiver is bolted on w/4 large bolts now......hoping that the new one will also bolt on, see no reason to weld....
