+1 size or not
ianmac23
I currently have 205/75r14 and it looks like I could go up to 215/75r14 on the same rim. I would gain 200 pounds in capacity. I am not maxed out but it would give me more room. What do you think?
Thanks
2010 GMC Sierra, 1500, SLT, Crew Cab, Short Bed, 6.2L, Max Towing Package,2011 Keystone Passport Ultralight Limited Edition
13 REPLIES 13
JIMNLIN
Tachdriver wrote:
coolbreeze01 wrote:
I go up a size or 2 and go for E rated tires. There are some good brand choices in 14", what do you intend to buy?
+1 on this, Kumho makes this tire. Check Tire Rack for specs.
The Kumho 857 is a D rated tire at 65 psi and a very good upgrade for tires on a trailer.
Just make sure your present 14" wheel can handle the higher pressures if you decide to go with them.
gotsmart
If the OP's wheels are 14" x 6" I suggest replacing them with 15" x 7" wheels - just for the better selection of available tire brands and sizes.
2005 Cruise America 28R (Four Winds 28R) on a 2004 Ford E450 SD 6.8L V10 4R100
2009 smart fortwo Passion with Roadmaster "Falcon 2" towbar & tail light kit - pictures
wa8yxm
Well, you will gain TIRE capacity, reduce the odds of a blow out and increase tire life as well as bearing life (Cooler not turning as fast).
What you will NOT do is increase the RV's cargo carrying capacity. That is a function of the axle and springs.
Tvov
And, most important, most trucks look better with larger tires....
You might have a slight change in your speedometer reading? But I don't think it would be enough to worry about.
_________________________________________________________
2021 F150 2.7
2004 21' Forest River Surveyor
APT
I did exactly that a last spring. Go for it!
A & A parents of DD 2005, DS1 2007, DS2 2009
2011 Suburban 2500 6.0L 3.73 pulling 2011 Heartland North Trail 28BRS
2017 Subaru Outback 3.6R
2x 2023 Chevrolet Bolt EUV (Gray and Black Twins)
Tachdriver
BurbMan
As long as you room for bigger tires in terms of top/side clearance, I would do it.
coolbreeze01
2008 Ram 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2014 Sandsport 26FBSL
fla-gypsy
Just do it!
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
09 SuperDuty Crew Cab 6.8L/4.10(The Black Pearl)
06 Keystone Hornet 29 RLS/(The Cracker Cabana)
Grandpere
Lets make it unanimous, definitely make the change.
Berniece & Russell Johnson
Lil'Bit, a Netherland Dwarf Rabbit
1987 Southwind
1995 Ford F150 Supercab
Life in the fast lane? No thanks, we will stop and smell the flowers at every opportuity
ianmac23
Yes 200 for each tire gained in capacity
Dakota98
YES, by all means.
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
midnightsadie
if thats 200# on each tire? I,d do it. how about ply rating that,ll up the #,s
