30amp power cord
tim1970
I was wondering if anybody that has an RV wired for 50amp service carries a 30amp cord for when they know they will be at a campsite that only supports 30amps. It seems like it would be better than having to use the large 50amp cord. I guess I also need to know if you can even buy a 30 amp cord that will plug into an RV designed for 50 amps. (Is the connector the same?)
Thanks
Tim
2017 Jayco 29.5 BHDS
30 REPLIES 30
wa8yxm
Lantley wrote:
The point of carrying a 30 amp cord is so you can avoid using the much heavier 50 amp cord if you don't need to.
That is why I have such a cord so SECOND on this post.
Bumpyroad
bucky wrote:
Because a percentage of humans will argue with a tree.
I will leaf that comment alone. ๐Ÿ™‚
bumpy
bucky
Bumpyroad wrote:
Why get out the heavy 50 amp cord if you only have 30 amp worth of power available?
Adapters do not eliminate the heavy cord from the equation. The OP's goal is to use the lighter cord when possible. The lighter 30 amp cord is available
x2
why is this "fact" so difficult for some to grasp?
bumpy
Puma 30RKSS
tinner12002
I also carry both with 3-4 adapters.
2015 Ram 3500/DRW/Aisin/auto/Max tow/4.10s,Cummins, stock Laramie Limited--Silver
Tequila Sunrise 2012 Ultra Classic Limited
2018 Raptor 428SP
Bumpyroad
x2
bumpy
Lantley
tatest
If I were, I would. And yes, such an adapter is available. You may not find everything in your RV powered.
With 30 amp service, I carry a 50-30 adapter in case I get into a site where only a 50 amp socket is available or it is the only socket working properly.
Some RV parks might have adaptors for rent, but I carry my own, they don't cost that much, don't weigh that much, and I can buy at the quality level I prefer.
Tom Test
Itasca Spirit 29B
RockyMt
50 amp unit- I have both 50ft cables as well aadapters. 30 amp has 50 plug, lighter than the 50 amp.
Lynnmor
I needed an extra cord at a nice park in northwest PA. The trailer cord and the extra cord were stretched like a clothes line to reach.
lawnspecialties
fj12ryder wrote:
Bumpyroad wrote:
lawnspecialties wrote:
I have both a 30A cord and a 30A adapter. But the thought of dragging that 30A cord around means it stays home 100percen of the time. I use it when the camper is in the driveway being loaded up for a trip. But it goes in the house garage before we leave.
you don't carry a spare additional cord?
bumpy
I don't, never needed it. It could happen but hasn't so far in about 10 years of periodic travel. It certainly could, but not so far.
Nope. Never needed it as well.
janstey58
X2 on the push a button to roll up my 50A cord!
Jeff and Kim
2015 Fleetwood Discovery 40E
Freightliner Chassis 380HP DP
2012 Ford Escape Limited Toad
rk911
Us out West wrote:
Lantley wrote:
Us out West wrote:
rk911 wrote:
Thanks
Tim
we carry a 50==>30 amp dogbone adapter for use in parks that don't offer 50-amp service. I doubt you'll find an RV that is wired for 50-amps but will let you plug in a 30-amp cord. that's what the adapters are for.
Same....thanks.
The 30 amp to 50 amp cord does exist no adapters needed.
Yes it only delivers 30 amp but it connects to the standard 50 amp RV twist connection
No need to carry extra power chords.
If the pedastal has 30 amp but not 50 amp here is what we have.
30M/50F AMP 18" Dogbone
yup, that's the one. takes up a lot less storage space than another cord.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
rhagfo
Thanks
Tim
Why bother with multiple cords just make the correct cable with 6/4 SO cable!
I carry 40' of 50 amp 6/4 cable in a three gallon bucket, not heavy, and can easily be coiled back into this bucket even below freezing.
The hand is for scale not holding the cable down, it is just resting on the cable. My 50 amp to 30 amp dog bone is also in the bucket :B
Us_out_West
Lantley wrote:
Us out West wrote:
rk911 wrote:
Thanks
Tim
Same....thanks.
Our Trip Journal
2012 Jayco Pinnacle (View)
36 KitchenPantryTripleSlide
MorRyde pin box and suspension, Curt Q24, Dual Pane windows, Auto Levelers, 2 AC's,and more.
2009 Silverado 3500HD 4X4 (View)
CC, Dura-Max 6.6/Allison,LB ,DRW,Amer. Tank 65 gal. Aux Fuel
