48 inch wide rolls of Eternabond tape?
ctilsie242
Apparently there are such things as 48 inch by 50 feet wide Eternabond rolls.
This gets me wondering... for a rig that is 100 inches in width, would three overlapped layers of this ensure the roof is well sealed for a long time, assuming one is able to get the Eternabond properly pressed into place around the items in the roof (vents, skylights, the A/C, etc.), as well as having it overlap the sides by an inch or two?
In theory, this would be interesting, but each 48" x 50' roll is about a grand in price, so it definitely isn't a cheap idea, nor likely a doable one, due to the need to make sure Eternabond is pressed into place at every inch.
17 REPLIES 17
MrWizard
Moderator
Moderator
I think the OP was pondering a theoretical exercise
About covering a roof without removing everything from the roof
I can explain it to you.
1997 F53 Bounder 36s
spoon059
Dutch_12078 wrote:
Wills6.4 Hemi wrote:
How much is it?
Best Materials has 36"x50' Eternabond at $512.95/roll.
EternaBond RoofSeal WHITE Repair Tape
With 3 rolls and additional seam tape, cleaner, primer, etc., that would make it at least $1700 plus shipping to do a complete 40' RV roof. Best Materials also sells EPDM re-roof kits that would only be about $1000 including all materials and tools needed.
I have to wonder how much Rhino lining is to do a job that size...
2015 Ram CTD
2015 Jayco 29QBS
Dutch_12078
How much is it?
Dutch
2001 GBM Landau 34' Class A
mr__ed
Im a fan of Eternabond but have only used it to seal roof seams, not the entire roof. Even though it's an excellent t product, I would opt for a roof coating that can be "painted" on. I'm sure there are some good products out there that can be applied this way. Would no doubt be less expensive, too!
Mr. Ed (fulltiming since 1987)
Life is fragile. Handle with prayer.
2007 Hitchhiker II LS Model 29.5 LKTG (sold)
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition (sold)
time2roll
I would be more inclined to use 2' wide and go across the roof. Start in the back and work your way forward.
Otherwise strip the roof of every fixture and get some 9' wide for the entire length :B
schlep1967
I want to know who is lifting that roll of eternabond up to the roof.
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
westend
I'd practice on sheeting the whole roof with a bonding layer product by using something like this: Grace ice and water shield
As was posted, the major leak points are not through the membrane but at any through hole areas.
'03 F-250 4x4 CC
Wills6_4_Hemi
How much is it?
noteven
Resident found taped to the roof of RV after tripping over roof equipment... police and firefighters on scene now...
pianotuna
Nomad III
Nomad III
I ordered some 48" wide to repair a roof on my home. It is special order.
Regards, Don
Dutch_12078
Re-roofing with wide Eternabond would be doable, but it would cost more than a conventional EPDM DIY re-roof kit. The labor would likely be similar anyway.
Dutch
gbopp
TomG2 wrote:
I purchased a roll that was something like 48" wide, but it was only 4" long.
(Old joke, sorry)
Kind of like aircraft pilots landing on short but, really wide runways? :B
TomG2
(Old joke, sorry)
korbe
My first thought is that it's the edge seams and utility protrusions that have more of a potential for leaking. With the wide rolls of tape you are paying for, covering areas that are probably not ready to leak is a lot of "extra" money, IMHO.
