โOct-29-2016 11:54 AM
โOct-31-2016 01:39 PM
Slownsy wrote:
Henry wher do you get that a gooseneck is rated double the toving weight of a FW.
Frank.
โOct-31-2016 12:58 PM
โOct-31-2016 08:54 AM
โOct-29-2016 07:49 PM
โOct-29-2016 03:27 PM
โOct-29-2016 02:16 PM
Old-Biscuit wrote:
Although your Cardinal is 'out of warranty' contact them and inquire
"Would the use of a gooseneck void my frame warranty"??
Answer YES
then question is why?
WHY.because pin box structure is NOT designed for the added leverage/stress a gooseneck can apply.
Look at the structural design differences between a gooseneck trailer and a 5th wheel pin box
One uses large beams/heavy supports/bracing-----other uses a wide spread frame with thin/light weight cross pieces and some web bracing.
One designed to carry/handle heavy/high stress loads----other designed to carry/handle much lighter loads spread out across the structure
Gooseneck...for gooseneck trailers
5th wheel hitch...for 5th wheel trailers
Right tool for the right job.
โOct-29-2016 01:53 PM
โOct-29-2016 12:40 PM
โOct-29-2016 12:36 PM
โOct-29-2016 12:04 PM
