โMar-09-2021 05:40 PM
โMar-11-2021 05:46 PM
โMar-11-2021 05:08 AM
mkirsch wrote:
Yes, definitely NOT trailer sway. Trailer sway does not go away by itself. However, trailers will move around with undulations in the road and gusts of wind. If they snap right back in line behind the truck, then you did not experience sway and there is nothing to reduce.
On the other hand if you had to manually apply the trailer brakes to bring it back in line, that's a whole other ball of cats.
โMar-10-2021 04:01 PM
โMar-10-2021 03:50 PM
โMar-10-2021 03:38 PM
blt2ski wrote:
I got moved half a lane getting hit by what where known 60-100 mph gusts on I205 crossing the Columbia river one time. Whole truck and trailer moved as a unit. While I'm not going to say my shorts didn't need changing. I don't consider that type of movement anything a Hensley or equal can help with.
If the trailer is moving left to right behind you on its own at speed above XX mph, that is when the cat is playing in those balls Don posted a picture of. I can say you have problems with the setup.
As noted by some others, what movements did you have? Some frankly are what many of us would call normal movements. Kinda like a plane in some wind conditions.....bouncy!
Marty
โMar-10-2021 10:22 AM
โMar-10-2021 09:14 AM
โMar-10-2021 04:56 AM
mkirsch wrote:
...that's a whole other ball of cats.
โMar-10-2021 04:48 AM
โMar-10-2021 03:30 AM
โMar-10-2021 03:29 AM
โMar-10-2021 03:19 AM
โMar-09-2021 08:01 PM
โMar-09-2021 07:09 PM
