Can I tow this- the early years....
Jerallen
Yep. Question is as old as the industry.
Moderator edit to re-size picture to forum limit of 640px maximum width.
10 REPLIES 10
BenK
Found this one years ago at that Canadian guy's site and IIRC, his
tread of any 'FWD car' can tow had this image as an example
That guy's setup needs some tweaking... :B
Trailer is pointing too high... :E
No WD, but single axle trailer, so must be a 10% tongue so 'half ton towable' for sure... :B
Of course the trailer brakes stop the trailer...so no need to have
any extra braking on this TV... :B
Betcha he can tow in OD !!!! and since not an automatic, won't hunt
gears...he has total control of which gear... :B
Today's road bike tires can be aired up to 120PSI, but back then betcha
he's at 35PSI...'P' class range...
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
REDF350
I wonder if it has a tow/haul transmission feature.
2003 Coachmen Catalina 300 TBS
2006 Ford F350, 6.8L, V10, 4.10
Husky 1000 WD
Camco friction sway control
Prodigy BC
Wife, Four Children (22G, 19G, 17B, 11G)
One Labrador
tatest
There's a pic somewhere of a bicyclist pulling an Airstream. Publicity department did it.
Tom Test
Itasca Spirit 29B
Road_Ruler
Buick's rock.
Moderator edit to re-size picture to forum limit of 640pz maximum size.
Bedlam
Moderator
Moderator
You just need to run a super single in the rear - No problem!
BenK
It will be just fine if it has the 'Max Tow' and 'HD' option...been
doing that for hundreds of thousands of miles with no problem
:B:B:B:B:B:B:B:B:B:B:B:B:B:B:B:B
93Cobra2771
Meh, I don't care how much power it has, it has too short a wheelbase. You need the dually long bed version cause, you know, it you don't have a dually then you can't pull any trailer except for a 5x8 utility. Duh!
Richard White
2011 F150 Ecoboost SCREW 145" 4x4
Firestone Ride-Rite Air Springs/Air Lift Wireless Controller
2006 Sportsmen by KZ 2604P (30')
Hensley Arrow
docnascar
This should get the job done. :B
Tow Vehicle
2017 Chevy Silverado 2500HD
6.0L gas. Double Cab
Travel Trailer
2020 Grand Design 2400BH
ScottG
It would take at least a dually Isetta..
mowermech
Cute.
But, obviously a staged picture.
Those Isettas could barely pull themselves with 2 people aboard. No way it could pull any trailer!
CM1, USN (RET)
2017 Jayco TT
