Do holding tank weathervanes glue to standard PVC pipe?
K3WE
Got one of these:
Weather-vane tank vent.
I took my tape measure to it and did not get a "nice even number" for either the inside nor the outside diameter.
I know that PVC insides are "nice even diameters", I maybe the outside of a standard PVC pipe will slide perfectly into it.
Anyone have direct experience connecting or gluing this to standard PVC pipe?
PS- NOT putting it on the camper, so please, no replies that it fits the camper vent...I know that much ๐Ÿ™‚
Thanks.
22 REPLIES 22
BurbMan
Exactly...the unit the OP is looking at comes with 3 screws and is designed to be mounted that way, not glued. YES, for the millionth time we get that you are not putting this on an RV.
My point was that this unit can be mounted to any 1.5" PVE, PVC or ABS pipe using the included screws. You DON'T want a glue install, any type of vent cap is meant to be removable so you can use the vent as a cleanout point for snake access if necessary.
The joint doesn't need to be airtight since air is escaping there anyway, hence why they call it a "vent"...
Dutch_12078
K3WE wrote:
It doesn't really fit schedule 40 1.5" pipe tight enough to call it compatible. A big glob of glue MIGHT work, but it's a tad loose...I can probably "stick it" and it will probably work, but I also bet there will be some gaps in the seal.
It's a vent cap... It doesn't need an air tight fit to work properly. Just secure it with a couple of short sheet metal screws. Gluing it will just make what's left of it harder to remove in a few years when it wears out and you want to change it.
Dutch
2001 GBM Landau 34' Class A
K3WE
spud1957 wrote:
The OP has stated he is not putting it on his RV.
Perhaps the OP could reveal the secret as to what he is putting it on. Maybe that will eliminate some of the confusion.
S
It's further up in the thread. I want to hook it to standard PVC pipe to vent a tank NOT on my RV to divert odors away from the house.
BY THE WAY- SINCE NO ONE KNEW THE ANSWER AND MOST (not all) POSTS WANTED TO ANSWER QUESTIONS I WASN'T ASKING ASKING, I bit the bullet and took it to the store with it (The cashier was looking so hard for the barcode to scan it and charge me for it)...
I thank those who read before they blurted out the wrong answer, and also thank the one individual who personally observed the loose fit and shared his valuable experience.
spud1957
S
2018 F350 6.7 4x4 CCSB
2022 GD Reflection 337 RLS
BurbMan
K3WE wrote:
I am constantly amazed at folks who are so cocked and primed to blurt out "follow directions" that they totally miss it when someone's asking something a bit unique.
Yes, it gets old. However, if you had read the Installation Instructions posted on Amazon, you may have noted the following:
Note: The Cycloneโ„ข RV Holding Tank Vent was engineered to fit the majority of RV holding tank vent pipes (1-1/2" PVE). PVC and ABS adapters are available at local plumbing and hardware stores to fit other pipe sizes.
The OD of 1-1/2" PVE and PVC are both 1.90", so use the appropriate fittings to change the vent pipe diameter to 1-1/2" on whatever it is you are venting.
Allworth
You could use some JB-Weld epoxy, but keep in mind that it will be PERMANENT. JB is stronger than the parts you are working with.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
Water-Bug
IAMICHABOD wrote:
beemerphile1 wrote:
K3WE wrote:
Got one of these:
Weather vane?????? How do you use that thing to predict the weather?
:h A weather vane only shows the direction of the wind, not the weather....:S
In some locations, a change in wind direction is a very good indication of a change in the weather. In other locations, it only means that the wind changed direction.
wa8yxm
Some things that MIGHT surprise you when you do this job
1: That pipe that sticks up.. Not PVC, it may be rubber
2: The vent pipe (Black PVC) rattles around inside it, NOT sealed.
Yup,
The "Weather Vane" will either fit inside or outside the rubber,, It won't run away on you.
IAMICHABOD
beemerphile1 wrote:
K3WE wrote:
Got one of these:
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
beemerphile1
K3WE wrote:
Got one of these:
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
John_Joey
K3WE wrote:
Dakota98 wrote:
ScottG wrote:
Don't over think this. You don't need fittings, glue or anything else. Just buy the device and it fits over your stack - there's nothing else to buy or be concerned with.
It's easy cheesy.
OP Quote:
PS- NOT putting it on the camper, so please, no replies that it fits the camper vent...I know that much ๐Ÿ™‚ :B
Dakota:
Thank you for your solid reading comprehension skills.
...and I know I can load it up, go to the store, take it inside, try to make sure that the anti-shoplifting police don't become concerned and try some PVC pipe...
I was just hoping that someone else had done what I'm going to do- use it to vent something OTHER THAN an RV holding tank.
Thanks again Dakota!
I get a little tired of it also.
When I put one on my rig it was a sloppy fit where normal PVC cement would not have worked. I would look at other glues that were thicker if you really wanted a permanent installation. Otherwise the three screws provided will hold it just fine.
Thereโ€™s no fool, like an old fool.
Rollnhome
K3WE
You said you had the part and wanted to know if it would fit. Seems simple enough to try it on the pipe you want to vent. Depends on size,schedule or SDR of pipe.
2008 Discovery 40X towing a Jeep Grand Cherokee
K3WE
Dakota98 wrote:
It's easy cheesy.
OP Quote:
Dakota:
coolbreeze01
Good excuse to buy a caliper.
2014 Sandsport 26FBSL
