Fresh Water Hose
derh20
I am wanting advice for a fresh ware hose that is easy to coil up to store. The one I have now I just bought at Wally Mart and not only is it impossible to coil up neatly, the water coming out has a bad odor and of course taste bad. Yes, it is for potable water. I have also tried a white hose (for potable water) similar to the green Pocket Hose that has been out for a couple years and not to be used for potable water. Although it was easy to store, the water taste bad. Any ideas out there?
33 REPLIES 33
Dtank
Cummins12V98 wrote:
Dutch_12078 wrote:
Dtank wrote:
Use that *Made in China* "Wally Hose" to water your lawn.....but - maybe you shouldn't - (might kill the lawn)..:(
The Camco TastePURE Premium RV water hoses that Walmart sells are made in the USA.
Try coiling one under 60 degrees.
Ya can lead a horse to a water bucket filled by a Camco TastePURE Premium water hose made in the USA - but ya can't make a *wise* horse drink from it!
It's neigh (nay!) for me -
but whatever rings *your* chimes or fills *your* bucket!..:C
Dutch_12078
I've coiled mine numerous times even below 32 deg.F with no great difficulty. Are they stiffer when it's colder? Yep. But they still coil without kinking.
Dutch
2001 GBM Landau 34' Class A
Laman
Well I have had two of the Camco white hoses for 6+ years and don't ever remember them being very difficult to coil even in 30 degree weather, never had a taste issue either. Not junk in my opinion.
1998 American Eagle 40' EVS, 2011 Ford Edge, Falcon 2 tow bar
DW and 2 DD's
Cummins12V98
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Dutch_12078
Dutch
Dtank
accsys wrote:
While not cheap, these are absolutely the best hoses available and definitely worth the money - oh so easy to coil!
Bingo! (finally!!)
What he said.....
"are absolutely the best hoses available and definitely worth the money - and oh so easy to coil!!"
X-297..;)
Any length you want, choice of couplings.
Quick delivery to your door.
Special configurations OK - like same couplings at each end.
Worth the "not cheap" - you *DO* get what you pay for!.:C
accsys
Cummins12V98 wrote:
Thanks, that's what I wanted to hear.
I will be placing an order!
You will love the quality. All hoses should have such good connectors! We purchased three 15 foot sections and usually only use one but it makes it easy to reach 45' if necessary. I also have a 50' length of the NeverKink just in case we are really a long ways from the water. But the one 15 foot section is good for 90% of our stops and two sections will handle most of the rest.
John & Doris
Doris and Robbies Blogs
2017 Cedar Creek Cottage 40 CCK
FMCA F380583, PA, Good Sams
DSDP_Don
Just so you know, most Arizona water tastes like******even when it's filtered.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
NMDriver
The water tasted normal. I am now at a complete loss. Any ideas would be of great help.
Go to one of your neighbors and ask to taste the water coming out of their hose. If their water tastes fine and it tastes fine out of the spigot then buy a new hose and or filter like the neighbor has. If the neighbors water also tastes bad then I suspect it is some aspect of water in hoses that you do not like and you may need to use bottled water for drinking.
5er/2500Duramax/18ftBoat
Cummins12V98
accsys wrote:
Cummins12V98 wrote:
How about in cold weather?
We don't normally camp in freezing weather but they coiled easily in 40 degrees.
derh20
My saga continues. I bought a new Never-Kink hose and it coils up nicely, although I am in AZ, so I don't know how it will preform in colder weather. I tested the water after it leaves the filter just before it enters the coach. Again, bad taste. So, I have illuminated the hose and the filter as the source of the problem. I then turned off the campground water and started my fresh water pump. The water tasted normal. I am now at a complete loss. Any ideas would be of great help.
D_E_Bishop
wilber1 posted;
"I do the same thing but I cut a 25' hose in half and put ends on both halves. My unit has the water hookup in the basement so I leave one hose hooked up and coiled in the basement. If I need more length, I add the other half. I also carry an additional hose if I need even more length.
If the OP is having problems with smell and taste using different potable water hoses, he should start by sanitizing the tank and the rest of the water system."
I think cutting the hose is a good idea and much cheaper than two 15's and sanitizing is a great idea.
As for me I have a 25 foot flat white hose and it coils up about 1.125 inches thick and 14" in diameter. These hoses were popular back when our Bounder was born. Ours was in the bay when the Bounder left the dealer. I have a second hose, a Camco but it hasn't been used yet. I'll use it for the drain when I sanitize this spring, that should take all the taste out(if there is any).
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
wilber1
Dutch_12078 wrote:
I carry one 10' white hose that I don't recall where I bought, and two 25' white hoses, one Camco from Walmart, and the other an unknown brand from Big Lots. None of them add any taste to the water, and all are fairly easy to coil and connect the ends together for storage without kinking. I've rarely needed all three, but it has happened. As said, the 10' is enough a lot of the time. All three were sanitized with a bleach solution before first using them.
"Never trust a man who has not a single redeeming vice" WSC
2011 RAM 3500 SRW
2015 Grand Design Reflection 303RLS
accsys
John & Doris
