Jul-18-2021 07:34 AM
Jul-20-2021 01:25 PM
Jul-20-2021 01:15 PM
mr_andyj wrote:
200 watts of solar and 2 GC batts will run indefinitely on a DC Danfoss style compressor fridge.
Gdetrailer, yes, your setup works, but the reason it is not favored by many is the residential just pulls a lot of amps, will shorten the battery life as a result, and as you say, 2 days is it, 4 with your 300watts.
Your setup is great for weekend warriors, but the power usage is so much higher that I dont recommend it myself. Everyone wants to trump their own horn I guess.
My first camper I tried a small residential fridge and inverter. I had 3 batts. It worked great when new, but over time the batts lost life and the fridge would run them down quicker and quicker. The inverter, which uses power just being on, had to be on all the time and loses efficiency through its loses, and eventually when the batts did lose SoC thee was not enough to start the little compressor, and the fridge was of no use until I charged batts back.Not a big deal, but those batts did not last as long as I would have hoped; back then they were cheap is the good part.
Now I prefer the Danfoss compressor fridges. Expensive, yes, but a lot more ideal for those not willing to compromise function over dollars. Im cheap but a few things I will not compromise on. The fridge is one of the cherished items in my camper.
Jul-20-2021 10:46 AM
Jul-19-2021 11:36 AM
mr_andyj wrote:
Im not in the group that thinks a household fridge is the way to go for camping.
Jul-19-2021 10:33 AM
Jul-18-2021 02:51 PM
JRscooby wrote:
From what I have seen few absorption fridges in RVs are in a cabinet shaped for good operation. The hot air from both coils and flame/heating unit must not pool at top of chamber. And all air must be guided past the coils to pick up as much heat as possible.
Jul-18-2021 02:00 PM
Jul-18-2021 01:12 PM
ivbinconned wrote:
Yes ok.
On 110 it does not cool. But there is power at the plug.
The tiny blue flame was burning from 8 pm till 8 am this morning. Top of chimney was hot to the touch but the fridge did not cool. Well perhaps slightly. Temp was 60F.
I shut off the propane dial and turned on the ac. With in 3 hours temp went up 15 degrees.
Jul-18-2021 01:01 PM
ivbinconned wrote:
Thanks for the manual.
It does not have electronic ignition so is it not the pilot that I see. And it would burn all the time?
What do you mean by “AC”?
Jul-18-2021 12:46 PM
Jul-18-2021 11:24 AM
Jul-18-2021 10:29 AM
Jul-18-2021 08:54 AM
