โMay-24-2017 06:37 PM
โMay-26-2017 06:27 AM
D.E.Bishop wrote:
I'm kind of surprised that no one has suggested that the OP buy an automotive test light instead of pulling the fuses one at a time. She needs to get a variety of fuses so why not get a basic 12vdc trouble shooting tool at the same time.
โMay-25-2017 09:28 PM
โMay-25-2017 09:27 PM
โMay-25-2017 07:43 PM
โMay-25-2017 11:10 AM
Cheryl_B wrote:
I'll see how those blue plastic things pull off the breaker box. They seem to have 3 lift-up tops. Not sure if they do but I'll play around with them and see how it goes.
โMay-25-2017 09:03 AM
โMay-25-2017 08:29 AM
โMay-25-2017 08:25 AM
โMay-25-2017 07:50 AM
โMay-25-2017 05:05 AM
horton333 wrote:wtmtnhiker wrote:
I agree it's likely the GFCI that is tripped, it may control power to many other outlets.
The GFI has nothing to do with a 12 volt light circuits, it is for 115 volt outlets.
If you look beside those blue plugs, the fuses, there may be a small red LED light on very close to the fuse. If there is that is the fuse that is blown. Otherwise as suggested pull them out one by one. You can see the melted wire inside of the blown fuse after you pull them out.
Amateur Radio K3EXU
โMay-25-2017 04:26 AM
โMay-25-2017 04:02 AM
down home wrote:
Look for the wall plug with the reset button in the middle and push it.
Ground Fault probably kicked out and everything on that circuit won't work.
Usually one near kitchen/shower and another elsewhere or two circuits.
If it stays tripped won't reset, then there is a short, now. Find the two wires or more touching and repair.
โMay-25-2017 03:52 AM
โMay-25-2017 12:23 AM
โMay-24-2017 08:57 PM
