โJan-07-2017 09:51 AM
โJan-09-2017 03:55 AM
ktmrfs wrote:wa8yxm wrote:
I agree the Pop UP TV sounds great till you relize that parked it is almost always UP and moving it is down. An overhead tv does not move and you still get shelf space. Either way you loose storage space except with modern Flat Screen TV's you can make it into a cabinet door very easily at the drawing board phase.
Refer in a slide....
I would rather keep the weight in the slide down as much as possible.. I worry about the weight in the slide. More stress on the hardware.
not in our case. I'd say 95 percent or more of the time the TV is down, we just seldom use it. About the only time it is used is if the weather is bad and we are spending some time relaxing inside. We camp 90-120 days each year. This last year we used the TV twice to watch a movie in the evening.
And with the tv down, we have a huge back window to see the outdoors. best of both worlds.
โJan-08-2017 04:59 PM
โJan-08-2017 11:47 AM
โJan-08-2017 11:16 AM
โJan-08-2017 08:08 AM
โJan-08-2017 07:41 AM
โJan-08-2017 07:32 AM
โJan-08-2017 06:33 AM
tinner12002 wrote:
So your telling us that a frig in a slide is vented different than one in a fixed position...how and why can that be if they are the same frig??
Bud
USAF Retired
Pace Arrow
โJan-08-2017 06:18 AM
SoundGuy wrote:
My current Coachmen has the fridge mounted in the more conventional manner so the exhaust vent is on the roof of the trailer and as such is not equipped with a fan to draw hot air out, certainly an advantage when dry camping. It's not the fridge but the installation that determines venting methods used.
Lynnmor wrote:
It is the wasted battery power from fans running that is my main objection. If you dry camp in hot weather, that wasted power becomes an issue.
โJan-08-2017 05:33 AM
โJan-08-2017 04:34 AM
โJan-08-2017 04:24 AM
MrWizard wrote:
TV's not really installed in 'kitchen counters'
โJan-08-2017 04:23 AM
โJan-07-2017 09:11 PM
