โDec-22-2013 08:08 PM
โDec-29-2013 07:01 AM
โDec-29-2013 06:04 AM
โDec-29-2013 03:47 AM
โDec-23-2013 07:19 PM
โDec-23-2013 06:53 PM
โDec-23-2013 05:24 PM
Horizon170 wrote:
For proper cooling this generator should run in the open. The sliding tray is the best idea for your situation IMO. If you need to run it while traveling have a portion of your door cut out and a smaller door installed with the hinge to the rear and open it just enough to form a scoop to force air in and have holes in the rear of your box for the air/CO to escape. BY ALL MEANS HAVE A FULL TIME CARBON MONOXIDE DETECTOR INSIDE. Sorry for the caps but this is most important.
My 2K Honda is mounted in a tray on the front bumper of my RV. I have a 10ga.electric cord run along the frame and to an automatic transfer switch so I can use gen.when traveling. I made an adapter to utilize both plug-ins on the gen to plug a 30 amp cord into.
โDec-23-2013 12:06 PM
โDec-23-2013 09:35 AM
โDec-23-2013 09:13 AM
โDec-23-2013 09:05 AM
joegray wrote:
Just my thoughts,,,,,, I would try to build a sliding tray so you could pull the generator out of the box. You could still leave it connected and not have to worry about any fumes or carbon monoxide getting into your unit. I personally, would not run the genny in the box.
โDec-23-2013 08:23 AM
โDec-23-2013 08:14 AM
โDec-23-2013 08:03 AM
โDec-23-2013 07:55 AM
