Liquid Wrench Dry Lube for Slideouts
BigSur2
Anybody have anything negative on this stuff? About to lube my slide rails. Went to Wally World. They had various dry lubes but the main ones were a Camco dry lube and a LW dry lube. The Camco - $9/bottle. The LW - $4/bottle. Just wanna make sure the extra $5 may have been worth it in the long run.
BigSur2
2016 Jayco White Hawk 33RSKS
15 REPLIES 15
Winged_One
I have been using the LW dry for years on the trailers slide rails, gears, 6pt leveling jacks, anything I don't want to attract road dirt (so basically anything external), without any issues and with good operation.
I use baby powder on the seals at least once a year. RV Geeks I use a pole to reach the center of the seals above the slides.
2013 F350 6.7 DRW SC Lariat
2011 Brookstone 354TS
Swivelwheel 58DW
1993 GL1500SE
Yamaha 3000ISEB
FlatBroke
Have Liquid Wrench dry lube and sprayed it on a squeaky bath room door hinge in my house. Sprayed it twice and squeak kept coming back. Used WD 40 once and the squeak is gone. So much for dry lube stuff.
Hitch Hiker
"08" 29.5 FKTG LS
2gypsies1
We never put anything on our slide mechanisms. We used 303 on the rubber around the slides. No problem in 16 years.
Full-Timed for 16 Years
.... Back in S&B Again
Traveled 8 yr in a 40' 2004 Newmar Dutch Star Motorhome
& 8 yr in a 33' Travel Supreme 5th Wheel
LOFAT36
Dry graphite underneath. Works for me.
JAXFL
I sprayed once then the next day drove.... Had a lot of road dirt stuck all on the slides
Happy Trails
JAXFL
2008 3100LTD Sun Seeker
2008 Chevy Colorado Z71 4x4 Auto Toad
Grit_dog
Navigator
Navigator
Never heard of powdering seals? What does that do for them or protect?
Slide rails on my old camper had remnants of grease on them.
I used chain wax (motorcycle chain lube). Good shear strength and less mess,like the stuff the op is looking at.
BigSur2
Yeah it's tricky one. I haven't checked the slide manuals yet, but if I don't see anything that tells me I should lube them, don't think I'm going to. Or maybe I will. Damnit!!!!! lol
BigSur2
Community Alumni
Not applicable
I use a spray dry silicone lube that I buy at Walmart on any moving/joint friction surface. This includes slide tracks, gears, stabilisers, hitch jack, and power awning components.
Sillybugs2
On our new rig the guy who did our walk through said use plain silicone twice a year on slide out.
2016 Hideout 28BHSWE
2008 Dodge Ram 3500 SLT 6.7L diesel 6 speed auto SRW longbed
Sillybugs2
BigSur2
So far have checked my main Jayco manual. No mention at all in regards to "how" to maintain them but that they are virtually "maintenance free". Need to see if I have another manual for the slides themselves, which I doubt.
BigSur2
belairbrian
It's Polytetrafluoroethylene, essentially Teflon. I have used the dupont brand of this for years on my slide rails and gears. Never caused a problem.
Lowe's has dropped the Dupont version so i bought the wd-40 version. Appears to be the same stuff. I noticed LW makes it with and without the for RV markings
TV 2007 Chevy 2500 Long Box Vortec 8.1/Allison or 2016 Tundra Crew Max 5.7L 4x4
2022 Freedom Express 192RBS
Equalizer 4 way WDH, Prodigy 3 BC
USAF Retired
WAR EAGLE
BigSur2
Thanks; I need to check my book. Its a Jayco. Any maintenance forum or youtube video you see says to use a dry lube.
Also for the rubber seals, I saw a manufacturer demo and they used silicone spray on a rag????
BigSur2
Old-Biscuit
My slide(s) mfg. also recommends no lube..........as in grease
Just wire brush rail teeth
BUT...
Since beginning of 2007 I have been using a dry graphite lube spray after wire brushing the rail teeth down. Goes on wet/sticks then drys. Doesn't attract dirt/grim BUT will rub off SO Careful Where you spray it.
Also use it on rear stabilizers pivot/contact areas and front landing gear inner and driven legs.
I spray silicone on a clean rag and wipe down the hydraulic piston shaft.
When FTng I would do the above monthly......past 2 yrs just bi-yearly
Also would put talcum powder in a sock and wipe down slide out seals/wipers
