โSep-02-2015 10:05 AM
โSep-30-2015 08:15 PM
โSep-30-2015 08:01 PM
โSep-03-2015 11:03 AM
โSep-03-2015 10:30 AM
j-d wrote:
I stand corrected. Chris is the one who knows, if he says "Wrench it" then that's what's most likely to work.
โSep-03-2015 10:26 AM
โSep-03-2015 08:45 AM
โSep-03-2015 08:17 AM
โSep-03-2015 07:44 AM
โSep-03-2015 07:40 AM
โSep-03-2015 06:30 AM
GordonThree wrote:Old-Biscuit wrote:
I love some of the suggestions......
pound on it, torch it, heat/chill it
Don't worry......the porcelain lining won't crack
Penetrating oil. Spray it/let it soak
Then tighten a bit to break bond then remove back/forth
since when are they putting porcelain linings in RV wh? I would think all the bouncing and jostling while rolling 10s of thousands of road miles would do more damage to any lining than heating the iron plug with a torch for a few minutes.
no lining in mine, just straight aluminum, I looked in that hole with a flashlight once.
โSep-03-2015 06:19 AM
โSep-03-2015 05:56 AM
โSep-02-2015 10:17 PM
โSep-02-2015 08:02 PM
