Mar-27-2019 10:17 AM
Mar-31-2019 06:51 AM
pitch wrote:
I do my Ram at 5000 miles. The Oil Life Monitor means nothing. Mine reduce ten percent for every hundred miles, towing driving or rolling!
Mar-31-2019 06:42 AM
Mar-31-2019 05:39 AM
Mar-29-2019 06:16 AM
wnjj wrote:Grit dog wrote:
Well I did seize up my snowbike last year, but I lost all the oil out of it.
That's probably because you change it so often. You're bound to forget to torque the drain plug. 😉 :B
Mar-29-2019 05:49 AM
Mar-28-2019 03:27 PM
Mar-28-2019 03:25 PM
Mar-28-2019 02:01 PM
filrupmark wrote:Perfect.
5000 miles for me .
Mar-28-2019 01:57 PM
Grit dog wrote:
How many engines you had that spun a bearing or dropped a valve or any other number of catastrophic failures before their time to make you paranoid to send in oil samples?
Mar-28-2019 01:37 PM
Mar-28-2019 10:43 AM
Mar-28-2019 10:01 AM
Cummins12V98 wrote:rhagfo wrote:Grit dog wrote:
Eric n Lisa is spot on.
Who the he__ does oil analyses on their pickups? No one I've ever known does. No one I've ever know does on their cars has either. And I hang around with a bunch of gear heads. And I've moved like 10 times in the last 25 years so plenty of "friends " in plenty of places.
Only ever heard of it on the Internet. Even being in heavy civil construction 25 years. Never personally seen an oil sample go in. Except maybe trying to diagnose a condition on an expensive engine.
If you want to change your oil every weekend, every year, every 10k miles, who cares?
Chances are your car will run a long time unless you never change it.
Better to do it at 3k 5k? Probably.
Going to blow up if you change 10k? Probably not.
To add to Eric n Lisa post. 1/ 2 cent a mile or what $100 a year for a couple oil changes? That's like 1/1000th of my total expenditure a year. I spend waaaay more just on beer and Copenhagen. Is that more important than an oil change?
If so, don't change your oil, who cares. If not then change your oil, who cares.
I get beer chew and oil at the same time.......
How people can brag or argue or bitsch about a couple bucks a year is beyond me. Do you only eat beans and rice or do you eat steak and not change your oil? Who the f cares?
Well I for one do, you can change your oil every 5,000 miles and take it to the auto parts store to recycle. I simply place a small plastic vial in the drain stream while changing. I then fill out the form with the unit number, mileage and other information. Now days I can drop the container in any mail box as postage is prepaid.
What do I get that you don't have a clue about? Metals contamination, are my rings or bearings wearing too fast. Fuel dilution is my oil being thinned by fuel? Antifreeze in oil, is a head gasket failing?
I get a peek at that engine health every 10,000 miles, or right now six months. It is saving the cost of an oil change, it is using the earths resources wisely. Dino oil hasn't changed the additive packages have.
This is the inside of our 2001 Ram Cummins tappet gallery at 300,000 miles.
Delo 400?
Mar-28-2019 09:19 AM
Mar-28-2019 08:08 AM
