Portable Ice maker
dtgunner7
What kind of water do you use in your portable ice makers, saw that tap water and distilled doesn't work well for very long..
24 REPLIES 24
mlts22
Tap water. Distilled water tastes "blah", deionized water tastes worse.
DeanRIowa
Tap water from our well.
2015 Summerland 2820 BHGS
2016 Silverado
DW Esmeralda, DS Mathew, DD Natalie
mhawk4
We use a Camco Evo water filter, so far no issues using tap water in ours.
1997 Ford F350 7.3L DRW
2016 Keystone Hideout 31RBDS
Blue Ox sway pro, Stromberg Carlson A-frame cargo tray CC-255
Luis,Shelia,Noah,Gabriel
All about the family!!;)
Wanderlost
Nomad II
Nomad II
We use tap water, unless it tastes odd, and then bottled drinking water. Either way has always been just fine. We've had our ice maker over 7 years, and it works like a charm still.
"The greatness of a nation and its moral progress can be judged by the way its animals are treated." -- Mahatma Gandhi
Czarny, black cat
Rainbow Bridge: Spotacus, Alexander the Grrreat, and so very many more
tinner12002
Plain ole drinking water in mine...no taste or function issues...but then the Crown would cover any ice taste anyway...lol.
2015 Ram 3500/DRW/Aisin/auto/Max tow/4.10s,Cummins, stock Laramie Limited--Silver
Tequila Sunrise 2012 Ultra Classic Limited
2018 Raptor 428SP
allen8106
Tap water 100% of the time, works perfectly.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
Vette_Racer
Out of the tap, into the ice maker!
KE5NCP
2016 Ram CC Dually, 2011 HitchHiker 349 RSB DA, 2018 Wrangler unlimited Rubicon
MrWizard
Moderator
Moderator
we use machine dispensed reverse osmosis ? water for our ice machine
or just buy bottled water, depends on whats available
I can explain it to you.
1997 F53 Bounder 36s
bob213
Halmfamily wrote:
We have a Brita Filtered water pitcher that we use to fill the ice machine. Takes the nasty tatse out of the ice. Going on three years with our machine and no problems
X2
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
JoeTampa
Bottled spring water for all drinking and ice since CG water varies too much in quality/taste to count on.
2006 Keystone Cougar 243RKS (First trailer)
2016 Jayco Jay Flight 32BHDS (Traded in)
2016 Jayco Jay Flight 33RBTS (Current)
2006 Chevy Silverado 2500HD 4WD 6.6L Duramax Diesel (LBZ)
Blue Ox Swaypro 1500 WDH
Prodigy P2 BC
Amateur Call AB2M
elwood58
MrWizard wrote:
elwood58 wrote:
fj12ryder wrote:
Why wouldn't distilled water work well? Seems like it would be the obvious choice.
Distilled water is one of the only things that will corrode stainless steel. Good for you, but not good for many metals.
NO it will NOT
your are thinking of De-ionized water
that can be corrosive to somethings
My mistake, it is Di water that can be a problem.
2016 Fleetwood Bounder 33C
dwayneb236
Water
2016 Ford F350 XLT DRW 6.7 SuperCrew 4X4 8 Ft Box
2016 Brookstone 395RL
AmericalVette
I have a 12 gallon "Life Mist" water distiller that is made of stainless steel. It's 11 years old. No corrosion anywhere.
Times fun when you're having flies!
Mmwtdh
