Sheets for RV matress
S-n-L
Hey All,
We have a king size sleep number bed in our 2008 Holiday Rambler Navigator. I measured the mattress and it was 72" X 80". Regular king sized sheets are 78" X 80" so they are very large and loose, which I really don't like.
Can anyone share info on where to buy sheets to better fit our mattress?
I did buy one set a few years ago from Camping World but I think they were expensive so I'd like to find other sources.
Thanks in advance,
Leslie
Stuart & Leslie Offer
2008 Holiday Rambler Navigator 45-Caspian IV, Cummins ISX 600. 2014 Jeep Cherokee limited,Cashmere. Roadmaster Sterling, SMI Airforceone. Full timing since June 1, 2014
11 REPLIES 11
S-n-L
Thank you all for your suggestions. I think I'll pick up a pair of sheet stays the next time we are at a Walmart.
Happy Trails to all.
Leslie
shadows4
Be wary of sheets from Camping World. We bought two sets from them last fall. We just opened one of the sets this weekend when we cleaned up the 5er for the coming camping season. Found two holes in the brand new sheet set. It has been maybe 4-5 months since we bought so to late to return. Also can't find the receipt. Love them except for the holes. (Maybe cause they are on my side of the bed!LOL)
2016 4X4 F350,CC,SB,Lariat,6.7L diesel,
2015 Coachmen Chapparal 324 TSRK
B&W Patriot 16K hitch.
RVcrazy
We bought ours from AB Lifestyles. Watch sizes! Camping world's are not 72 x 80.
Bob___Ann
We found the best solution is to put a memory foam mattress topper on top of the mattress. Now regular sheets fit and we sleep much better. It is well worth the money.
Bob and Ann
Schnauzer - Della (Rainbow B 3/31/17)
Chihuahua - Lola (Rainbow B 12/26/18)
Autumn-Red Poodle
2019 Tiffin 40 IP Bus
Powerglide Chassis
Cummins 450
Onan 10,000 Watt
Four Slide/ 1.5 Bath
2021 Jeep Unlimited Sahara Toad
Demco Dominator & Airforce One
missourijan
I have posted this many times. Buy a pair of men's suspenders at Wal Mart. Lay them out in an X pattern under the mattress. Attach them in 4 places to the side of the sheets, they are adjustable for any size mattress and hold any sheet tight.
wilcamp
We had a firm, home-style mattress custom-made by an Amish craftsman in Ohio's Amish community near Mt. Hope, Ohio. We took the measurements to another Amish lady living just a mile or so from the mattress shop. She made a fitted sheet that works just fine. Always good to support the local business community.
For those wondering how?, both shops had diesel generators to operate the professional machinery in their respective shops. Some Amish sects do permit and encourage such "modern" adaptations for their productive business enterprises, so long as they are "off-grid" from our "English" power supply.
Wil, Tara, Keeko (Jack Russel/Chihuahua mix 9 yr.-old) and Kalee (Wire Hair Terrier/Blue Heeler mix 1 yr. old)
2018 Rockwood Ultra-Lite 2702; 2014 Dodge Ram 1500 Big Horn Crew Cab 5.7L Hemi w/ 3.92 rear axle
KE6IRJ
72x80 sounds closer to Cal. King
Brian
2010 Keystone Springdale SG294BHSSR
2006 Ford F250 Superduty SB 4x4
Nicholsfamily05
We use sheet stays on all the mattresses.
Hubby hates it when the sheets get loose. So we have them on the house beds and the Rv beds.
Get them at Walmart a pack of 4 for 3 bucks
Easy to put on and we say well worth it too.
2016 Ram 3500 4x4 Big Horn Crew Cab, SRW. Cummins Turbo Diesel Automatic 68RFE Trans
50 gallon diesel Transfer Flow tank with the Traxx 3 system.
2017 Sierra FLIK 5th Wheel
42' Front Livingroom, 15K
Hydraulic level up system
darsben
DID YOU TRY GOOGLING 72x80 sheets?
TRY IT
LOTS OF SUPPLIERS
AMAZON, SEARS, EBAY AND TONS OF OTHERS
SELF HELP THE BEST HELP
Traveling with my best friend my wife!
Ed_Gee
S-n-L wrote:
Hey All,
Thanks in advance,
Leslie
Very puzzled by your size bed. Every size chart I have seen shows a standard King, including the Sleep Number mattresses as being 76 x 80. A California King is 72 x 84. Your measured size is neither of these leading me to suspect you are measuring wrong. Sleep number does not seem to have a bed in stock that is your measured size.
I suspect you have poorly sized sheets. We always have purchased our sheets from Lands End ... better quality and better fit.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
Dutch_12078
We use a set of "sheet garters", elastic bands with clips that connect across the corners of standard bottom sheets under the mattress to pull out the slack. Walmart and many other places have them for around $5.
Dutch
2001 GBM Landau 34' Class A
