Skipg wrote:
What’s your thoughts about leaving a RV plugged in to shore power when not in use. I read it not good for the house batteries.thanks for your input.
I have heard that too but..... Some things are outdated.
For example when I was growing up it was advised not to let gasoline engines idle for long periods or things got.. well Gummed up (Valves aned plugs) but today.. Click and Clack (The tappit brothers. Car Talk when it was still on Public radio) Said with modern computer controlled cars.. No problem.
Back then you could idle a diesel all day but today... DO NOT DO THAT.
Likewise with Plugging in an RV
Years ago many RV's especially trailers. had a Magnetek 6300 series converter which was kind of a strange beast by today's standard.
IT supplied raw rectified DC to lightes and fans and such. (Up to around 30 amps) and for senistive loads it provided about a 3-4 amp charge the batery and let the battery run the Fridge. and such.
NOT a good system at all.
I just saw a photo of one even worse in another thread (I actually had one like that I modified and improved).
With those. You do not want to leave the RV plugged in NO WAY.
Today however low end units often have somethign like a parallex 7300 (Parallex bought the old Magenetek line and upgraded) This is not a good converter (Single stage) But it is very well regulated (The Magnetek was not).
Some have a 7300T (Better)2 stage timed boost/bulk
Most have modern 3-stage converters Most of these sense the battery state of charge and adjust their output so that if the battery is hungry they push as much as 14.6 (Give or take) at up to labeled amperage to swiftly recharge... Same as oh. a GM alternator does.
Then as the battery fills they slow down and when it's full they drop to 13.6 (12 volt battery float voltage) neither charging or sucking power from the full battery.. You can leave those plugged in forever.
NOTE This is how the battery charger module in a UPS works too. And those are plugged in 24x7.
So. before you decide.. Find out what kind of converter you have.
