Sway Control options - help please
Janie_Ryan
We are a 2019 F150 ecoboost with towing capacity of 13,000 lbs. We are pulling a 2015 TimberRidge 28' trailer, 6933 lbs. We have a Reese equalizer hitch system (1000 lbs bars).
We are looking to add some sway control but there are many options.
We could add the Reese sway to our existing system; We could add just add a different brand of sway control; or we could get a whole new system (Camco eaz lift and Fastway E2 hitch systems have been recommended by friends) Looking for opinions to guide us. TIA
Dennis & Janie Ryan,
RV - 2014 F150 4x4
23 REPLIES 23
Lwiddis
What is your TTโ€™s wet and loaded weight? What is your TTโ€™s tongue weight wet and loaded?
ScottG
WDH systems are one of those things most of us have to buy more than once. We save a few bucks and go the cheap route. It "works fine" but not great.
Eventually some of us spend more and find out what we we're missing.
TenOC
Get a used Hensley Arrow from eBay. Problem solved..
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
wing_zealot
Lynnmor wrote:
How about this one?
This one will work just fine. No need for anything more.
DutchmenSport
When we still had a TT, we changed from the Reese bar and chain with friction sway bar to the Equal-i-zer 4 point 14,000 1,400 hitch and had absolutely no regrets. Trailer was 35 feet long. We now have a fifth wheel.
opnspaces
Navigator II
Navigator II
Since you already have a Reese I imagine adding on the dual cam is the most cost effective. If you want to change teh hitch out completely I would go with the 4 point Equal-i-zer hitch. I have one and it works well for me.
Link
Lynnmor
How about this one?
carringb
X2 - If you already have the Reese system, it's a minor upgrade to add the dual-cam setup, which works very well.
2014 ORV really big trailer
2015 Ford Focus ST
ScottG
If possible, use the Reese Dual Cam system. Worked better for us than and friction based system.
