WeBeFulltimers
Dec 09, 2015Explorer
Lantley wrote:Old-Biscuit wrote:
Sounds like a lot of OCD and waste of water
Toilet burps......dump
Shower/sink start draining slower...dump
Water pump goes 'burrrrrrrrrrup'..........tank empty add water
Otherwise if you use your Rig then you know how long you can go and when it's time to dump. No need for chemicals, high water use, monitors etc.
Waste holding tanks.......hold it/dump it repeat.
Biscuit I'm with you. I never use my tank monitor. I don't know if my sensors work or not. Once I become familiar with my rig I find no use/need for the sensors.
I see the tank monitor as a gimmick for newbies to give them peace of mind to know their rig will not blow from poo if they over fill there tanks.
Initially the tank monitor maybe beneficial but in time you'll know when it's time to dump without checking the monitor panel.
I try to avoid using chemicals unless absolutely necessary. I don't consider tank sensors necessary.
I'm in total agreement with you both!
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
