โDec-20-2016 08:46 AM
โDec-24-2016 02:53 PM
โDec-23-2016 09:57 AM
wa8yxm wrote:
First: If you have 100 PSI at the park pedestal DO NOT HOOK UP Your RV is likely rated for no more than 50 PSI..
โDec-23-2016 08:03 AM
โDec-22-2016 04:14 PM
โDec-20-2016 07:27 PM
Bob Vaughn wrote:
You hook your water hose to the pedestal and lay the hose in the sun. As the sun heats up the hose and the water inside doesn't the pressure inside increase also ? So at the pedestal you have say 100 PSI wonder what it would be at the RV on a hot summer day?
โDec-20-2016 06:01 PM
โDec-20-2016 04:16 PM
Lynnmor wrote:2oldman wrote:myredracer wrote:Good points.
Psi inside your camper would remain the same as the incoming CG pressure. If you are thinking your hot hose could drive the pressure up from the CG faucet connection all the way through the municipal distribution system back to the water system source (dam, well, lake), not possible. If you had the CG faucet off, any pressure increase in the hose and RV piping would be insignificant.t.
Gil beat me to it again, he saves me a lot of typing.
โDec-20-2016 03:31 PM
โDec-20-2016 01:41 PM
โDec-20-2016 01:37 PM
โDec-20-2016 11:49 AM
โDec-20-2016 10:58 AM
โDec-20-2016 10:53 AM
โDec-20-2016 10:41 AM
