โSep-28-2017 08:53 AM
โOct-07-2017 03:23 PM
โOct-05-2017 07:28 AM
rhagfo wrote:Turtle n Peeps wrote:RinconVTR wrote:itguy08 wrote:BenK wrote:
Pictures worth a 1,000 words... :B
Perhaps not using pictures of 10+ year old engines may be worth even more words..... The 6.0 went out of the Ford trucks in 2007. The Duramax and Cummins have also changed a lot in 10 years.
Extremely poor comparison...even below a typical marketing gimmick!
Not only is that image drastically outdated but look at the stroke length differences! Of course the longer connecting rod is significantly beefier. The people who produced that image are idiots.
Think about this:
I have a 8 cylinder engine that puts out 400 HP. (50 HP/ cylinder)Then I have a 1 cylinder that puts out 400 HP. (400 HP/ cylinder)
Which rod do you think is going to have to be bigger? :B
True that Cummins puts out as much as the V8's with two less cylinders, so some parts are naturally larger. It is a far more stout engine than the other two, just compare the overall weight of the other two.
What surprised me was i saw a cutaway of the Ford 6.7 diesel at the Homestead NASCAR race last year. The rocker arms were Stamped flat steel!
โOct-05-2017 06:50 AM
2112 wrote:
The F250 weighs over 2000lbs more than an F150. I get 20.5 MPG running empty on the highway in my EB. If I dropped 1 ton of payload in my bed I would get probably about 12 MPG. Hitch a trailer to it and it would only get worse.
โOct-05-2017 06:35 AM
Think about this:
โOct-05-2017 06:34 AM
โOct-05-2017 06:14 AM
The turbos load up at about 1800 RPM and I can see it happening on the instantaneous fuel usage indicator. The turbos on a 3.5EB F250 would always be loaded, 100% duty cycle and would suck the gas. Forget 4WD. That would only make it worse.
An F250 with a 3.5EB would get horrible gas mileage empty.
That would remove the incentive of owning the truck.
โOct-05-2017 03:39 AM
โOct-04-2017 10:35 PM
โOct-04-2017 09:16 PM
โOct-04-2017 09:00 PM
โOct-04-2017 08:16 PM
โOct-04-2017 08:03 PM
โOct-04-2017 03:29 PM
โOct-03-2017 11:38 PM
