nail file for my dog?
charlysmom_dad
I'm hoping to get some god advice from forum members.
We have no problem clipping our dogs' nails, but we have on dog that seem really pointy. I want to buy a doggy nail file. I'd like one that won't bog down when I use it. Electric plug in, or rechargeable lithium would be fine. Anyone using one that they can recomend? Thanks in advance
2015 Thor Vegas 24.1
21 REPLIES 21
Lemorand
I use dog nail grinder. Found one in this article ***Link Removed*** Its is called Lucky tail nail grinder. It works so well, makes trimming process easier and less painful for a dog.
xteacher
I have an 3-speed dremmel from Harbor Freight Tools. If your dogs have long hair, be sure not to get the hair caught up in the dremmel. You can pull a woman's knee high stocking over the nails up to the foot to get the hair out of the way, exposing just the nails. On my small dogs, I use the dremmel on low. When I had bigger dogs, I used it on medium. You can buy replacement sanding rounds at Home Depot or Lowes.
Beth and Joe
Camping Buddies: Maddie (maltese/westie?), Kramer (chi/terrier?), and Lido (yellow lab)
2017 Keystone Bullet 248RKS
2014 Aliner Expedition Off Road
2013 Ram 1500 HEMI
Crowe
Yikes..that would hurt! Good luck next time the dog sees the dremmel!
LOL! It hasn't happened in years but when we first started using a dremmel it did happen once. And yes, it was QUITE the challenge after that! Years later we have no issues.
I may not have gone where I intended to go, but I think I have ended up where I needed to be
Douglas Adams
[purple]RV-less for now but our spirits are still on the open road. [/purple]
AJBert
I let my dog run on our gravel drive way to his heart's content. Not only does he get the exercise he need but I don't have to ever worry about his nails.
pennysmom09
Crowe wrote:
Plug in Dremel. One upside is if you cut too close to the quick it cauterizes the nail.
Nancy and Doug
2015 KZ Durango 325RL FW
charlysmom_dad
Thanks for the replies. We have small dogs.
LJAZ
My vet uses a Dremel and for what it's worth Dremel actually makes a version specifically for pet nail grooming. The model # is 7300-PT, it's cordless and cost $25 at home depot.
2011 Chevy Silverado Crew Cab 4X4
2009 Funfinder 210 WBS
Prodigy P3
CA_POPPY
If you check your local beauty supply, a cordless dremel will likely be less expensive than a pet supply. For a large dog, though, you will need the pet version.
Judy & Bud (Judy usually the one talking here)
Darcy the Min Pin
2004 Pleasure-Way Excel TD
California poppies in the background
2012Coleman
Boxer Lovers wrote:
Oster makes an adjustable speed electric dog nail kit. Like a Drimmel. Several small sanding wheels. No sharp edges. Check at a pet supply store.
This...
2018 RAM 3500 Big Horn CTD
charlysmom_dad
It sounds like dremel is the way to go. I didn't know they made a rechargeable dremel. I'll look into that.
Thanks so much for all the great replies.
Campinghoss
I use a dremel also. Both of ours tolerate but do not like having their nails clipped. They do not mind the dremel. I always use a new sanding wheel and have never had a problem. It is really great on their dew nails.
Camping Hoss
2017 Open Range 3X 388RKS
MorRyde IS with disc brakes
2017 F-350 6.7 with hips 8'bed
Lucie our fur baby
Lucky 9/15/2007 - 1/30/2023
Pawz4me
Depends on the size of the dog. For smaller dogs I prefer a rechargeable (battery operated) Dremel. They only last a couple of years or so, but you can pick one up at WalMart for less than $25. So it's not a huge expense. The plug in Dremels are IMO too powerful for use on small dogs. If you have a larger dog with thick nails you probably need the extra power. Either of them can work for medium sized dogs, but I usually prefer the rechargeable Dremels for those dogs. I'd rather spend a few extra seconds per nail with a less powerful tool and have more control. The trade off is well worth it to me.
Me, DH and Yogi (Shih Tzu)
2017 Winnebago Travato 59K
Crowe
Douglas Adams
Bionic_Man
I have our dogs nails trimmed. The groomer uses a plug in Dremel. It works well. I should probably buy one myself.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
