โJul-25-2019 07:27 AM
โJul-29-2019 12:44 PM
Sandia Man wrote:No. As mentioned, a breaker does not trip the instant it reaches it's rating. It's NOT how standard molded case breakers work. A breaker has an inverse time-current characteristic as shown in the standard graph below. They have a thermal magnetic element in them. As the element heats up, it trips sooner at higher currents. At short circuit levels, the magnetic element trips it instantaneously.
Head on over to your local wallyworld, they have a variety of adapters to handle any scenario. No circuit breaker required on adapters as your RV has a main breaker that will instantly open upon reaching its rated value. We use our 50 amp adapter often for our 30 amp rig since many power pedestals at older parks have very worn 30 amp receptacles.
โJul-29-2019 12:36 PM
fj12ryder wrote:SoundGuy wrote:Yes, I know. I was trying to make a point about DSteiner51 stating:fj12ryder wrote:
So if I'm reading this right, if I plugged my RV into the dryer outlet, if it fit of course, no harm would come to my RV because they're both 240 volts? Correct?
Your RV is wired for 120 vac main service, NOT 240 vac. What do you think will happen if you plug your 120 vac trailer into 240 vac source power? :E
"If in fact my house is 240 volts and my dryer, range, and well pump, then my 5th wheel is also 240 volts. When I use a volt meter and jump between my two hot bars in my RV it reads 240 volts. Horrors!"
โJul-29-2019 12:27 PM
philh wrote:LOL! If you were an EE, you'd have to deal with something called "imaginary power"... ๐
As a mechanical engineer, I don't deal well in imaginary numbers...
Are RV pedestal 50a circuits single phase or two phase?
โJul-29-2019 11:50 AM
โJul-29-2019 11:46 AM
โJul-29-2019 09:52 AM
philh wrote:I think the common term is split phase since you can use either the 240v between the hots or 120v from hot to neutral. Although single phase would be correct based on the single coil source. Some call it two phase since the two hots are 180 out of phase from each other. Definitely not three phase.
โJul-29-2019 09:20 AM
โJul-29-2019 07:44 AM
โJul-29-2019 07:21 AM
philh wrote:Single phase 120/240V
โJul-28-2019 05:50 PM
โJul-28-2019 11:57 AM
โJul-28-2019 11:50 AM
DSteiner51 wrote:So if I'm reading this right, if I plugged my RV into the dryer outlet, if it fit of course, no harm would come to my RV because they're both 240 volts? Correct?rk911 wrote:fj12ryder wrote:
Just get a 50 amp to 30 amp adapter. You plug your 50 amp plug into it and then into the 30 amp pedestal. Easy peasy.
and no, a 50-amp RV pedestal is not 220-volts. it is two separate legs of 120-volts, each leg capable of supplying 50-amps. you can safely connect your 30-amp RV to the 50-amp RV pedestal using the 30-female/50-male dogbone adapter
My house has 2 120 volt wires come into my main breaker box and a double 200 amp breaker. Farther down are several double breakers, 1 for the dryer, 1 for the range, 1 for the well pump, and 1 for my 5th wheel. In my 5th wheel the main breaker is again a 50 amp double breaker. If in fact my house is 240 volts and my dryer, range, and well pump, then my 5th wheel is also 240 volts. When I use a volt meter and jump between my two hot bars in my RV it reads 240 volts. Horrors!
โJul-28-2019 11:41 AM
โJul-26-2019 07:00 PM
โJul-26-2019 03:58 PM
