2 66 lb batteries
AStinker-
Listed below are 2 batteries that are the same weight but each has a different Ahr rating. The Ahr and weight came from spec sheets.
235 Ahr / 66.0 lb = 3.56 Ahr / lb
240 Ahr / 66.0 lb = 3.64 Ahr / lb
Hypothetical question:
If you had to buy batteries based on this single fact which is the better buy?
19 REPLIES 19
skipnchar
Heavier plates in general last longer than waffle plates. I'd go with the weights of that were the only concern. May mean little or no difference in USE but can mean you'll be using them longer.
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
pianotuna
Nomad II
Nomad II
Hi,
Since I prefer 12 volt jars, I would buy neither of those.
Regards, Don
EsoxLucius
Impractical question: If you had to buy batteries based on this single fact which is the better buy?
There has to be more involved in the decision between two batteries than that.
2013 LTV Unity MB Theater Seats
635 watts solar panels, 440 AH batteries, BlueSky Solar Boost 3024iL & IPN-Pro Remote, Magnum MS2000 & ME-RC50 remote
Koni Shocks F & R, Hellwig 7254, SumoSprings F & R
2012 Hyundai Accent SE, Blue Ox Aladdin/Patriot
SeaDog_BRR
I myself have never carried about the weight of a battery. I want the max AHR for the given size of my battery box/tray. both being equal I would go for the most AHR
Greg aka SeaDog Ret Navy
2016 Flagstaff 26 FKWS TT
96 Winnebago Adventurer 34RQ W/SO (selling)
06 F350 6.0, Harley Ultra Classic ๐Ÿ™‚ 64 corvette ๐Ÿ™‚
BFL13
Did you put the 66.0 there or is the spec 66? If 66, then rounding off could make them the same weight.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
