โJul-08-2015 04:42 PM
โJul-10-2015 06:32 AM
โJul-09-2015 06:23 PM
RoyB wrote:Lookup WLBZ in Bangor Maine, it transmitts on RF channel 2 and displays as 2.1.
There is NO MORE LOW BAND TV signals from 0-13. ....
Reese Dual Cam Straight Line HP Sway Control
โJul-09-2015 06:12 PM
โJul-09-2015 04:57 PM
โJul-09-2015 03:14 PM
โJul-09-2015 02:25 PM
โJul-09-2015 12:12 PM
โJul-09-2015 11:09 AM
wa8yxm wrote:
What antenna do you have? the Winegard Batwing is a VHF/VHF/UHF antenna.
The Jack is not
โJul-09-2015 10:36 AM
SaltiDawg wrote:
RoyB is 100% correct.
โJul-09-2015 04:27 AM
โJul-08-2015 10:06 PM
โJul-08-2015 09:21 PM
SaltiDawg wrote:Roy is wrong (and that doesn't happen much) and so are you.
The old network stations generally retained their VHF Channel designations after the change, but they are actually broadcast on UHF frequencies!
As an example, the "old" Channel Five Fox station here in DC still displays as Channel 5 Fox. However it is now broadcast at a UHF frequency associated with a UHF Channel number of 14 or higher.
I think when Roy said, "You will find them designated 2.1 3.1 etc but the new frequency band starts at the old VHF channel 14 and up." he actually meant "You will find them designated 2.1 3.1 etc but the new frequency band starts at the old UHF channel 14 and up."
Otherwise, perfect explanation.
โJul-08-2015 08:07 PM
โJul-08-2015 07:43 PM
โJul-08-2015 07:11 PM
