โJul-08-2015 04:42 PM
โJul-12-2015 07:58 PM
winnehonda wrote:In the chart I posted, WPEC only lists the RF channel 13. I assumed that the RF and virtual channels were the same but it turns out that WPEC is virtual channel 12 and RF channel 13. Your TV only displays the virtual channel number.
In my area channel 5 (NBC) and channel 12 (CBS) are local. In prior motorhomes these stations were captured on Air-channel scan. They included 5.1, 5.2, etc. Just call me Still Stumped!
โJul-12-2015 04:39 PM
โJul-12-2015 12:29 PM
โJul-12-2015 12:01 PM
โJul-12-2015 11:26 AM
โJul-12-2015 09:59 AM
โJul-12-2015 08:36 AM
winnehonda wrote:If your antenna is a Winegard Sensar or Jack, it needs 12 volts at the antenna head on the roof. Disconnect the coax from the antenna and measure the voltage between the outer part of the F-connector and the center conductor.
Tom and others, thank you for your input. The thing tat is driving me crazy is one time I was able to capture these lower channel and the reception was great. Later, it was lost. I have tried every combination in trying to recapture these low channels. To no avail.
โJul-11-2015 04:05 PM
โJul-11-2015 09:29 AM
winnehonda wrote:I checked TVFool.com and there are two VHF stations close to you. WPTV and WPEC. You should point your antenna to 193ยฐ.
Have a 2015 Class C with Samsung TV and antenna booster. When I search for channels over air I can only lock in upper UHF channels. No 2-13 channels. I called Samsung and they got terribly confused about the antenna booster. When connected to cable I can receive all available channels. Any thoughts?
โJul-11-2015 05:36 AM
โJul-10-2015 11:11 PM
Tom_M wrote:Actually on UHF there were many as long as the analog was the lower of the two. Just happened to be how the channl cavities performed, its been a while.. We ran channel 34 Analog and 35 Digital for several years, and pretty sure there was a D36 to boot..
At the beginning of the digital transition, TV stations were broadcasting both analog and digital signals. Since the VHF band was mostly filled up, that meant the digital had to be broadcast on the UHF band. Once the analog was shut down many stations moved their digital broadcast down to the VHF band. About 1/4 of the full power TV stations in the U.S. are broadcasting on VHF. The UHF band used to go to channel 69 but presently it ends at 51. I don't think the TV band will fill up any time soon. Digital broadcast actually freed up many channels. During the analog years you could not have adjacent channels in the same market. For instance, there could not be a channel 10 and channel 11. There had to be a gap between channels. With digital, adjacent channels are permitted.
โJul-10-2015 07:14 PM
โJul-10-2015 06:55 PM
โJul-10-2015 10:17 AM
