โAug-24-2013 07:18 AM
โAug-25-2013 01:15 PM
โAug-24-2013 12:38 PM
otrfun wrote:
I just noticed as I turn on each 12 vdc light, the input current reading on the PI EMS (110 volt line side) to the converter jumps up approx. 1 amp for each light.
โAug-24-2013 12:12 PM
โAug-24-2013 10:58 AM
โAug-24-2013 10:40 AM
โAug-24-2013 10:12 AM
โAug-24-2013 10:08 AM
2oldman wrote:I just installed a Progressive Industries 30 amp hard-wired Electrical Management System between my outside 30 amp L5-30 connector input and my breaker/converter panel. The remote display gives realtime input voltage, current, and line frequency, in addition to all the protection it provides. Very cool device.
First time I've heard of someone being able to measure the input amps to a converter. What sort of meter setup do you have?
โAug-24-2013 09:42 AM
enblethen wrote:
A standard amprobe will read input amperage. Of course it must be on the wire.
OP:
What kind of rig do you have?
What meters are you using to read the amps and voltages?
โAug-24-2013 08:51 AM
Bud
USAF Retired
Pace Arrow
โAug-24-2013 08:39 AM
โAug-24-2013 08:27 AM
โAug-24-2013 08:22 AM
otrfun wrote:
Noticed the 110 volt input current to my converter fluctuates significantly with load. When the battery is fully charged, sometimes the 110 volt input current jumps from 1-2 amps to 6-7 amps by just turning on 4 or 5, 12 vdc lights. Is the converter simply reacting to the voltage drop (from the increased 12 vdc load) and increasing charge current/voltage to compensate? I assume this is normal? Thanks!
โAug-24-2013 08:17 AM
Bud
USAF Retired
Pace Arrow
โAug-24-2013 08:02 AM
