โJun-28-2016 06:20 PM
โJul-01-2016 06:40 PM
joebedford wrote:Wow, very nice!otrfun wrote:Remove the thingy with the hanging lamps? I don't think the ceiling is open - the a/c vents into the ducts only.
We also have a Voltage. I assume your a/c unit is located, overhead in the main living/kitchen area. If you're not happy with the way it's currently cooling, I would highly suggest temporarily removing the ducted a/c ceiling assembly to see if your overall cooling improves.
โJun-30-2016 07:59 PM
otrfun wrote:Remove the thingy with the hanging lamps? I don't think the ceiling is open - the a/c vents into the ducts only. This isn't my rig - this is a stock photo.
โJun-30-2016 12:54 PM
otrfun wrote:Thank you. 2" is really going to limit air circulation, IME.westend wrote:The ductwork appears to be about 2x8 in size and made out of a grey-ish colored, pliable kind of hard foam about 1/4" thick.
I would bet that the heat transfer between ceiling cavity and duct is horrendous. Are your AC ducts insulated ducts or are they akin to a clothes dryer vent?
โJun-30-2016 10:22 AM
โJun-30-2016 10:09 AM
joebedford wrote:We also have a Voltage. I assume your a/c unit is located, overhead in the main living/kitchen area. If you're not happy with the way it's currently cooling, I would highly suggest temporarily removing the ducted a/c ceiling assembly to see if your overall cooling improves.
Ductwork sealing was terrible in our Voltage. I had to retape every opening and retape the unit on the roof.
Helped a lot but it's still not very effective in the LR and totally useless at cooling the garage.
I would open up the ceiling to bypass the ducting altogether too, but there is a big valence? with light fixtures on the ceiling blocking access to the a/c.
โJun-30-2016 09:41 AM
TomG2 wrote:Good idea. I thought about that, too. I believe the ceiling assembly itself is the only difference between the ducted and non-ducted a/c rooftop units. Could be wrong tho.
Could it be as simple as replacing the ducted ceiling unit with a un-ducted one?
โJun-30-2016 09:15 AM
fischer wrote:I hear ya. I read posts like this all the time and sometimes it's difficult to visualize everything. Unfortunately, I didn't have my phone with me when all this went down.
I think pictures would have been nice to see. Just saying
โJun-30-2016 06:55 AM
โJun-29-2016 08:45 PM
โJun-29-2016 03:25 PM
โJun-29-2016 03:02 PM
โJun-29-2016 11:35 AM
โJun-29-2016 09:56 AM
otrfun wrote:down home wrote:What's your definition of "cool"?
Why? You like a ho bedroom while the living area is cool?
Both our units are front and then one over the kitchen area with connecting ductwork.
Sometimes only one unit, the rear or main one, is needed as the cooled air is spread throughout the coach.
We can close the bedroom door and be cool and no noise at tall, fro the ducts in the bedroom.
