Flat Leaf Springs- Replacement Required?
1slomofo
Please see attached image.
I have noticed this at the beginning of last camping season and I ran it like this for a little over 800 miles since I noticed it. I am due for other maintenance and would like your opinion on whether or not I should add new leaf spring packs to the to-do list.
This is on a 2015 Eclipse Attitude 32SAG Toy Hauler w/ Lippert 6,000lb axles. I am not sure what springs to replace them with if I go that route.
-2015 32SAG Eclipse Attitude Toyhauler
-2010 Mosebilt 2-seater Long Travel Sand Car
-2008 GMC Sierra 2500HD Duramax
-2006 Kawasaki Kfx400
-1984 Wife
37 REPLIES 37
fj12ryder
I'd keep the equalizers. Those are the EZ Flex from Dexter and if the rubber isn't deformed, are well worth keeping. They work a treat.
Howard and Peggy
"Don't Panic"
BurbMan
When we got our Terry TT new in 2008 we found out that they made it with the wrong springs....I had the opposite problem tho, they used springs that were TOO stiff and it was shaking the trailer apart going down the road.
They grab springs from big crates as these things roll down the assembly line and there is a very little visual difference between various rated springs. Entirely possible they made your with the wrong springs. Pretty much SOP in the industry to use axles rated to just cover whatever weight is not carried on the tongue/pin. Even running at max capacity your springs should not have deformed like that.
I would replace with a heavier spring just to give you some more headroom in the ratings and also replace those shackles and equalizers too.
1slomofo
Edd505 wrote:
1slomofo wrote:
enblethen wrote:
Are all the springs showing the same?
I would weigh the rig first.
I would be looking at complete spring, shackles and link replacement
Look on etrailer.com for what packages are available.
Yes they all look exactly the same > Flat .. maybe even slighty bending the wrong way in the middle.
I did weigh it "trip ready" (aka loaded to the gills, full water etc) and it was 13,800lbs total give or take (pending my math on how much is sitting on the truck) 11,400 would be on the trailer axles.
6K axles with 13,800 loaded, see anything wrong?? Two 7K's get you just barely, get a pair of 8K axles to carry the weight and have a bit of wiggle room.
Yea I agree there is plenty wrong with that. They literally rely on pin weight of the truck to take up the slack on the under sized axles. The trailers gvwr from the factory is 14000 and they have 12000lbs of axle. And they make thousands of these things.
-1984 Wife
Edd505
C Schomer wrote:
He also Said 11400 on the axles. Iโ€™d look for 3500s... for 7k axles as long as they are the same eye to eye. Craig
Dexter 7K & 8K are identical except the outer bearing and lug size 1/2" vs 9/16" Not sure on the 6K
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
C_Schomer
Edd505
pianotuna
Nomad III
Nomad III
Hi,
Last fall I replaced the rear springs on my class C E-450. They looked better than yours--and when the spring shop disassembled them one leaf was broken. The cradles for the air bags had broken welds on both sides.
I got new springs made up with an extra leaf on each side, and added Timbrens as to replace the air bags. They could not source air bags that would fit the E-450, which may be why the oem ones failed. The Timbrens have about 1/2 inch of clearance without the fresh water tank being full.
There was a big upgrade in drivablity and sway. It was a great decision to make the change.
Regards, Don
1slomofo
pauldub wrote:
If you're anywhere near Santa Ana, get in touch with Deaver Spring.
Turns out I'm in Santa Ana everyday.... I will for sure!
-1984 Wife
pauldub
Lynnmor
Your springs are spent. One source of springs is a farm equipment store, I bought from one and the parts were better than the originals.
Lwiddis
Agree! Replacement time.
wa8yxm
Springs do wear out but I see no breaks in them.
There are shops that can tell you for sure. I'm one one of them.
Matt_Colie
Get it to a scale and then go find a truck spring shop. They can fix it right the first time.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
enblethen
Try to get a rough eye to eye. Looking at etrailer, you should be able to use ones that are within a half inch or so. The kit installation "should" give an over-all length.
Measure width of springs
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
1slomofo
Ltrip wrote:
I just went through that with my 2018 Arctic Fox 25Y. Yours look pretty bad. Figure out what is the stock spring and then upgrade by 250-500 lbs on each spring. The key measurement is the eye to eye measurement when unloaded.
Good luck.
Well.. I am not sure my springs will return to normal enough to measure eye to eye .
Should I just measure the hangers on the trailer frame instead?
-1984 Wife
