โSep-26-2014 07:12 PM
โSep-27-2014 05:41 PM
dougrainer wrote:
The freezer CANNOT get too cold. The normal range of a freezer is 10 degrees to -10 degrees. The temp sensor on ALL RV absorbsion refers regulates the regular refer NOT the freezer and there is NO temp adjustment on a RV freezer. Doug
โSep-27-2014 04:21 PM
mdock2 wrote:
But if you are having to defrost the freezer every week, there just might be a problem, will post a thermometer report.tks
marty
โSep-27-2014 03:30 PM
โSep-27-2014 01:19 PM
bigfootford wrote:wolfe10 wrote:
What refrigerator do you have?
Most RV/absorption refrigerators have the thermostat in the refrigerator only.
And, yes if you have a question about temperature in either refrigerator or freezer, put a thermometer in and verify actual temperature.
True...
If you want your freezer compartment get colder leave the fridge door open for a while.. Opening it and getting a cold beer every hr will further cool the freezer compartment.
I have dual wireless temp transmitters to monitor fridge temps House and Rig.
They work like a champ...
Jim
โSep-27-2014 10:36 AM
โSep-27-2014 08:57 AM
j-d wrote:
Those wireless thermometers are great. Ordered a set from Amazon. Didn't work. Sent back no hassle and fortunately decided to order replacements. This set is faultless. It's good to re-set the High/Low feature once the fridge has cooled down.
โSep-27-2014 08:45 AM
โSep-27-2014 08:37 AM
โSep-27-2014 07:00 AM
โSep-27-2014 06:35 AM
โSep-27-2014 05:52 AM
โSep-27-2014 05:22 AM
โSep-27-2014 04:57 AM
Old-Biscuit wrote:Kiwi_too wrote:TXiceman wrote:
Frost in the freezer bags does not mean the freezer is too cold. That is simply moisture from the food that had frozen.
Ken
X2
X3
Air in storage bags has moisture and it will ice up
A faulty or fallen down thermistor (temp sensor in food section) would cause items (milk, eggs, vegetables etc.) in food section to freeze.
Also you being in cold area refrigerator is more efficient at changing ammonia coolant state (liquid to vapor to liquid) so it stays a lot cooler.
