How to get shows off DirectV DVR
Randu
I'm up grading to the new HD system but don't want to loose the recorded shows from my old standard definition DVR. Is there a way to download into computer before installers show on Tuesday and remove my old DVR? Randu
2017 Chevy 3500HD SRW Crew LTZ
4x4,Duramax, Allison.
2017 Jayco North Point 381DLQS
Previous: 2000 Travel Supreme
2005 Newmar Kountry Star
2008 Mobile Suites 36TK3
14 REPLIES 14
Randu
riven1950 wrote:
I did the same a while back and asked DT. They said watch them before the conversion or lose them. There may be a way to do it, but to me not worth it to figure it out. BTW the new DVR is sooo much better, larger storage, etc. worth losing some recorded shows IMO.
Thanks for the suggestions but decided to go into a watching marathon that started Friday night with some priority input from wife about which shows were "Need" to see vs. "Want" to see. Reminded me of trailer shopping with need /wants. Down to 3 Master Chefs, 8 Rosalie & Isles, and 12 Bones which fell to the bottom. Randu
wa8yxm
Theory has it there is a way Two of them in fact. One is not for the faint of screwdriver (Requires you OPEN the DVR and frankly I have not the instructions nor the software required)
Method 2 you need a TV TUNER card for your computer and play the shows into it, You need not watch them but play them into the card, record the card. There is some "Generation" loss but you likely won't notice it.
This will, however, tie up the computer and the DVR for some time and you need to hop over every 1-3 hours to set up the next show.
htwheelz67
If you leave your sd box disconected from the dish before you deactivate it you can plug it in and watch the recorded content, that is what I was told by directv.
Otherwise you will have to copy them using a dvd recorder.
MrWizard
Moderator
Moderator
The files are encrypted to the DVR
The only way is video copy while playing the recorded shows
I can explain it to you.
1997 F53 Bounder 36s
riven1950
MM49
Illegal as hell
mm49
dapperdan
You could pick up something like this and connect your DVR to your computer but that's just the half of it. You would need to install codec software, something along these lines to make it work. I've been able to do it, just keep in mind HD programs and movies will take up a LOT of space in your computer! The up side is you won't lose your favorite shows/movies.
Hope this helps.
Dan
hitchup
The SD version won't be half as good as your new HD version.
When we upgraded one of our HD DVR's to the Genie in the new Suite, we had to make a decision which one had the best recordings to keep. So we moved the LR HD-DVR to the bedroom (watched all the bedroom taped shows, then deleted) and had them put the new Genie into the LR. I like the ability to store even more shows and tape simultaneously from 2 DVR's.
We tried to get a 3rd Client for the outside TV, but the DTV Tech insisted it wouldn't work. So he canceled that part off our order.
Fast Forward to a few weeks ago, we had to get a Tech out to see why we couldn't get local channels. Also had the DTV Tech install the wireless Client to our Genie and a bridge picks up the HD signal to the outside TV. Finally a perfect picture on the outside TV instead of the fuzzy one we tried to get with a DirecTV splitter only.
2014 DRV Mobile Suite Estates 38RSB3....our custom home
2014 Ford F450 KR CC 4x4......his office
2015 Lance 1172 TC.....mobile Motel FOR SALE
Working Fulltimers since 3/2005
"Shoot for the Moon! Even if you miss it, you will land among the Stars."
valhalla360
Nomad III
Nomad III
They just put the USB port on the DVR to taunt you.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
2oldman
When I copied a lot of Simpsons from VCR to DVD I just had to play them all. Took weeks.
Now that I've made a personal reply, I can safely add that google has a lot of hits on 'copy dvr to computer', if you haven't looked there already.
DougE
Radio Shack has an RF Modulator that you will probably have to pair with a TV Tuner for Windows like the AverTV Hybrid Volar Max to input on a USB port. Windows Media Center can handle it from there.
Currently Between RVs
kmbelt
Sounds like 4 straight days of watching your recordings to me as i don't think Direct will let you save them off. I know Dish would let you save them to an external drive.
2014 Ram 2500, 6.4 Hemi, CC, 4x4
2010 Puma 259RBSS
JaxDad
donn0128 wrote:
No. You will need to make a list and reenter them manually.
The OP said "recorded shows" unless they come back on again setting the DVR to record them again won't do anything.
To the OP, the only thing you can do is to use a second recording device, like a computer with video capture software, to record them off your DVR as they are playing, it's slow but can certainly be done.
donn0128
