Okay boys, what did he do wrong?
partsman01
So on this GMC K2500HD I bought the owner had a LED back up light installed, they used those things you put on the wires and then squeeze shut with pliers and it saves you time as it is quick, anyway, found out when backing up light is on, but as soon as I touch the brake pedal it goes out, appears he hooked up to one yellow and one light green wire going into bumper 7 way plug in, I think it should hooked to yellow, but the other should be ground, should it not?
Thanks
Bill
29 REPLIES 29
Chris_Bryant
RoyB wrote:
This is a typical wiring pictorial for the 7-way trailer connector.
Most of the time the center pin is use for BACKUP lights.
Confirm this with a MULTIMETER to be sure...
Photo from GOOGLE IMAGES
also note in my case my FORD truck ignition key must be turned ON before I get any DC readings going back to the trailer connector.
Roy Ken
That is not at all the standard RV wiring for a 7 way plug.
-- Chris Bryant
BurbMan
Escargot wrote:
Ha! I know the answer but I'm not a boy, so, oh well.
Really?; That douchebaggery rises to the highest level. If you cant help the OP then don't post.
nineoaks2004
dougrainer wrote:
Correct. YELLOW is the back Up light wire color. The Green(if standard tow wire colors are followed is the tailight signal wire). So, you are getting a feed back. The Ground on the Tow plug is the large white wire. Doug
X 2
By the time you learn the rules of life
You're to old to play the game
Executive45
Bobbo wrote:
He assumed GREEN/GROUND. He was wrong. Move the connection from the GREEN wire to a real ground.
BINGO !
Bobbo
Bobbo and Lin
noteven
๐Ÿ˜„
landyacht318
Those wire taps tend to break about half the stranding on the wire into which they tap. I spent a while removing all the one the previous owner of my vehicle used. The wire stranding on every wire near a tap was broken and severely corroded. I had not had issues at that time, but it was just a matter of time.
j-d
This eTrailer Link
shows the center pin as Backup while the diagram above calls it AUX.
On the linked diagram, Yellow looks like what should have been connected (Called "reverse lights) to the Hot side of the LED, and its Ground wire should go to White/Ground. If it's LED, polarity matters. The light's ground should be on White.
If the LED is connected to the 7-way, make sure the wiring isn't damaged or loose.
Like RoyB said, most likely whatever color is to the Center Pin for the Hot, and Ground to White, Terminal #1, or any other good Ground.
Those pinch things are called Scotch-Locks.
partsman01
Thanks, just seemed odd to see the light go out, so figured he used the wrong wires, but maybe the ground will be the issue.
Thanks
RoyB
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
dougrainer
Dakota98
I believe if you disconnect what's been done & determine which wire is hot & which ground for the light itself then connect the hot directly to the back-up light circuit you'll have better luck. Should be pretty easy.
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
ScottG
Usually when symptoms like that arise, it's because of a missing ground.
Escargot
2006 Pleasure Way Plateau TS, MB Sprinter
enblethen
Bad ground connection.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
