โApr-15-2014 12:05 AM
โMay-14-2014 12:46 AM
โMay-13-2014 10:14 PM
therink wrote:x 2 If you don't remove the weber pressure regulator, you end up having two regulators as there is already one on your trailer propane system.
You will need to remove the regulator on the weber for it to work.
โMay-13-2014 09:58 PM
โApr-15-2014 07:00 PM
โApr-15-2014 06:54 PM
โApr-15-2014 02:46 PM
cochise49 wrote:
How do you control the propane flame? Maybe I'm missing something but I think the regulator and control is one unit on my high pressure grill.
โApr-15-2014 02:03 PM
โApr-15-2014 10:30 AM
pdogg wrote:
Camco makes a series of hoses, with the quick disconnects.. but what I can tell you is there are small differences between manufacturers... Mr. Heater also makes disconnects, and I can tell you from experience, while they look similar, they are not compatible..
Stick with one brand, and you'll be ok...
โApr-15-2014 09:23 AM
โApr-15-2014 08:17 AM
naturist wrote:
nor is it the same as an older propane quick connect fitting used as recently as 2007 on my TT. In fact, the two propane fittings look identical to the eye, they are just enough different that they will not engage each other.
โApr-15-2014 05:49 AM
โApr-15-2014 05:19 AM
โApr-15-2014 03:37 AM
โApr-15-2014 03:20 AM
