Propane Quick Connector hose to BBQ
GON2SKI
The AF 27-5L has a plug in quick connector feature (marked BBQ on the side of the trailer). I want to buy a hose to run between the Weber Q2200 connection and RV quick connector. Is this part available or is it something I need to have made up at a propane supply store?
2014 Arctic Fox 27-5L 5.5 Onan propane, 4pt AutoLevel, RearCam, Central Vacuum Bridgestone R250's tires
2002 F350 Power Stroke Diesel 4x4 CC SRW SB Chipped, Toyo Tuff HT tires
DW and 2 Bull Terriers
Here For A Good Time.... Not For A Long Time
14 REPLIES 14
Paul_Clancy
I took my webber 100 and the quick connect hose that came with the trailer to my local BBQ shop down the street and told them I wanted a 20ft hose with same ends and with the quick connect on the webber and regulator removed. Done $80 parts and labour. Another option for those who don't want to mess with propane hose and fittings
tvfrfireman
therink wrote:
You will need to remove the regulator on the weber for it to work.
x 2 If you don't remove the weber pressure regulator, you end up having two regulators as there is already one on your trailer propane system.
RangerEZ
Found this great thread tonight after pulling my hair out over hose that doesn't fit. I have the trailer listed in signature. How do I figure out which type of quick disconnect it has?
GMC 2500 HD Duramax
2016 Cougar X-Lite 28RDB
2015 Wildcat Trail Limited & 2015 Brute Force 300
red31
My trailer's quick disconnect is a 5LPA and not the model 250 which is now standard. Yep, low pressure but they used a 5LPA, mbsturgis set me right, they are here also
http://www.gashosesandregulators.com/propanequickconnect.html
hbillsmith
It took me about 10 minutes using the Calore parts. There are two phillips head screws that secure the regulator assembly. Unscrew those and lift out the entire regulator assembly. Take a look at Rons email or my youtube and you can see how to do it.
Wildcat2016-295rsx GMC2015-2500HD-DblCab D'max/Allisn+4x4 6.6'Bed
Maxxis235/80/16E;Andersen Ultimate2+4"offset;Airlft1 WirelessComp;GroundCtrl3;MorRyde RubbPinBox+CRE3000;3-Slidecovrs;Champion3100w/DIY ExtndRun;10'Portabote+5hp;Furrion48cam
Visited States
Ron3rd
cochise49 wrote:
How do you control the propane flame? Maybe I'm missing something but I think the regulator and control is one unit on my high pressure grill.
Could be on yours, on the Webers the regulator simply screws off and you control the flame with the knob as usual. The regulator is no longer needed as you're taking regulated gas off most trailers with the quick disconnect they come with. If taking high pressure gas unregulated off the tanks with an Extend-A-Flow kit (like I did with my old trailer) you leave the regulator on.
Equilizer Hitch
Honda EU2000
cochise49
Bev& Keith
2014 Winnebago Adventurer 38Q
2013 Honda CRV, Roadmaster Falcon AT, Invisibrake
Ron3rd
pdogg wrote:
Camco makes a series of hoses, with the quick disconnects.. but what I can tell you is there are small differences between manufacturers... Mr. Heater also makes disconnects, and I can tell you from experience, while they look similar, they are not compatible..
Stick with one brand, and you'll be ok...
You're correct. The Calore website I posted in my link has everything needed. They actually made a special quick disconnect fitting for the Weber that makes it simple and fits their hose perfectly. The only other thing you need is the Watts 1/8" coupler I also posted IF you are not going to put a shutoff at the Weber itself.
Equilizer Hitch
Honda EU2000
pdogg
hypoxia
naturist wrote:
nor is it the same as an older propane quick connect fitting used as recently as 2007 on my TT. In fact, the two propane fittings look identical to the eye, they are just enough different that they will not engage each other.
The length of the nose of the fitting that goes into the newer coupler is slightly longer. Just enough to frustrate us.
Jim
2007 Monaco Signature Noble III ISX 600HP
Ron3rd
Simple job, but you need the right parts. Here's how I did mine:
Weber Conversion
Equilizer Hitch
Honda EU2000
naturist
Yes, that hose with connector is a stock item. Propane supply store is likely going to be unable to make one up for you, as they probably don't deal with RVs. @RVBill3 gave you the link.
@therink also is right. You will have to remove the regulator on the Weber, as the quick-connect offers already-regulated low pressure gas, and that won't flow through the second regulator at all.
Finally, although it is very unlikely you'll have a problem with the item from CW, be aware that the propane quick connect fitting is NOT the same as a similar compressed air fitting (in case you decide you'd like to get fancy on us), nor is it the same as an older propane quick connect fitting used as recently as 2007 on my TT. In fact, the two propane fittings look identical to the eye, they are just enough different that they will not engage each other. Stupid, I agree, but folks sometimes run into appliances/hoses/fittings that don't mesh, and this is why.
therink
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5th Wheel, 12,280 lbs loaded (scale)
2015.5 GMC Sierra Denali 3500, SRW, Duramax, CC, Payload 3,700 (sticker- not scaled yet)
Take my posts for what they are, opinions based on my own experiences.
RvBill3
The hose should be available from places like Camping World. I think the hose you need is this one:
http://www.campingworld.com/shopping/item/12-propane-hose-assembly/67312
(This is not based on personal experience with that grill, so check for yourself if that is the one with correct connectors)
2012 Forest River Sunseeker 2300 Chevy
