shore power is not working
dkennedy
Class A diesel cannot use microwave, 110 outlets, or air conditioners with shore power, but can use them with generator. Why don't the 110 outlets and appliances work when plugged in but will work with generator?
11 REPLIES 11
jwmII
Could be a bad relay in the transfer switch not allowing the shore power side of the switch to connect.
jwmII
Tennessee_Nomad
If your shore power cord has one of the yellow aftermarket plugs on it (the pedestal/male side) unscrew the cap on it and and make sure the wires are all connected. I had the same experience and I had a wire loose inside the plug. Hooked it back up and all was good.
2010 Keystone Montana 3455SA Quad Slide
4 Goodyear G614's
2017 RAM 3500 DRW 4x4 Crew Cab
6.7L Cumminsยฎ Turbo Diesel
B & W Companion Hitch
All Made In USA
*I chose the road less traveled... Now I don't know where the hell I am*
j-d
oops
cruiserjs
Terryallan wrote:
Check the breakers on the pedestal. I'm guessin they are tripped
Yes check the pedestal. A smart camper before you probably TURNED the breaker off before he unplugged! You shoud A. turn it off before you plug in ( don't forgrt to turn it back on) and also turn it off before you unplug when breaking camp!!
Colorado Cruiser
Cruiser CF29CK 5th wheel; 2009 GMC Sierra 2500HD, 2wd, short bed
wonderful lifetime traveling companion/spouse
j-d
This is a DP so no doubt it's a 50-amp coach. Does the list of things that do not work include everything that's 120-VAC (shore tie or generator) powered or just some of the 120-VAC items? 50A is really two 50A circuits at 120-VAC each. Or 100A total available to the coach.
So I was wondering, the items to check remain the same, but it could be that only one Side/one Leg is out...
Old-Biscuit
Bobbo wrote:
1. Power pedestal
2. Transfer switch
THAT just about covers it..........
Add power cord.
Terryallan
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Ed_Gee
In a related comment, you should probably disconnect from Shore Power BEFORE you start the generator. If not, when the transfer relay breaks the shore power connection and switches to generator, arcing could occur which can burn the relay contacts and cause such problem as you are describing.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
Harvard
Typically, the transfer switch normally closed (NC) contacts service the shore power. When the generator fires up there is a slight delay then the power from the generator throws the transfer switch to supply the power from the generator. So, firstly, check the pedestal for power.
Bobbo
1. Power pedestal
2. Transfer switch
Bobbo and Lin
Ranger_Smith
Sounds like a problem with the shore power side of transfer switch. bad cord etc.
Where we are now
Amateur Radio Operator WW1SS . . . Flex 6500 PGXL and TGXL
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
