โMay-21-2015 09:19 AM
โMay-21-2015 06:26 PM
โMay-21-2015 05:45 PM
jwmII wrote:ralphnjoann wrote:
I'm not sure if a drill bit will work since the bit has to rotate clockwise to bite into the material but the plug has to come out counter-clockwise. I used a hacksaw blade to carefully cut through it, front to back, in a couple of places then used needle nosed pliers to pull out the pieces. Another way would be to use this, which can be found at Ace, Home Depot, etc.
Left hand drill bits are available and just for info left hand thread taps are available as well.
โMay-21-2015 02:36 PM
โMay-21-2015 01:59 PM
โMay-21-2015 01:01 PM
โMay-21-2015 11:37 AM
โMay-21-2015 10:08 AM
โMay-21-2015 10:07 AM
pulsar wrote:
I carry a large straight-flute screw extractor, purchased at Sears. I've only used it twice, once on my rig and once to help a fellow camper.
it worked fast and easy.
A sprinkler nipple extractor (Lowes or Home Depot) works the same wan and just as easy. Neither damages the threads.
Tom
โMay-21-2015 09:54 AM
โMay-21-2015 09:49 AM
popeyemth wrote:
Flat head screwdriver driven in and turned with vice grip pliers
If no center hole heat the head of screwdriver with a propane torch
โMay-21-2015 09:33 AM
โMay-21-2015 09:32 AM
โMay-21-2015 09:30 AM
Tom
โMay-21-2015 09:24 AM
