โDec-05-2013 01:14 PM
โDec-06-2013 12:01 PM
westend wrote:Corrosion isn't airborne. But the reason that the patio lights are not completely air tight (other than the fact that it would cost a fortune) is to allow it to breathe and dry out. Even the Starlights 1000 with all its electronics inside has a purpose-cut vent on the bottom of the lens to allot it to breathe.
I put a $1.85 LED panel in my porch fixture and it is perfect for me. You really want the fixture to be sealed so corrosion doesn't get in there.
โDec-06-2013 09:20 AM
โDec-06-2013 09:10 AM
the_armadillo wrote:
You may also want to look at the StarLight Revolution 300 (300 lumen) bulb or even the Starlight 1000 fixture. We replaced both of our outside fixtures with the StarLight 1000 because we like the motion detector feature. You can get the fixture or bulbs in black or white housings depending on what works best for your purpose.
Note that this bulb is not warm white... We use the amber lens in our StarLight fixures.
โDec-06-2013 05:40 AM
โDec-06-2013 04:41 AM
โDec-06-2013 02:49 AM
โDec-05-2013 07:50 PM
โDec-05-2013 07:34 PM
โDec-05-2013 04:44 PM
โDec-05-2013 04:32 PM
โDec-05-2013 03:26 PM
โDec-05-2013 03:10 PM
โDec-05-2013 02:39 PM
โDec-05-2013 01:47 PM
96Bounder30E wrote:No. I use a 4x4 wafer for porch. It's not as bright as the incan, but it won't burn the plastic either.
does the porch light need a waterproof bulb like what is in it now?...or would a LED panel be OK?
