โMay-30-2019 03:40 PM
โJun-04-2019 03:58 PM
โJun-04-2019 02:17 PM
โJun-04-2019 08:32 AM
โJun-03-2019 09:45 AM
Bigfoot wrote:
Your warning should not be limited to the 2011-16 Duramax.
2011-current Powerstroke diesel
2019 Ram with Cummins
Jeep/Ram eco diesel
Titan with Cummins
Am I missing anything here?
Looks like GM is the only one to drop the CP4 in the last three years...
โJun-02-2019 10:33 PM
1320Fastback wrote:ksss wrote:1320Fastback wrote:
Well know issue, so is the plastic cooling fan grenading and taking out 3 wiring harnesses and coolant lines. Also will severely damage your hood at the same time.
Well known issue, fan grenading? First time I have heard of that. Good thing your in a 92 Dodge, they never break. Crazy things happen, no matter what emblem is on the hood. There are motors that are notoriously bad, 6.5 not too good, IH 6.0 and 6.4 really bad. The Duramax is a proven engine. As is the Ford 6.7 and the 5.9/6.7 Cummins. Things happen and the odds are against it being catastrophic, even with the CP4 (like around 2% as I last read), but when it happens to you, the odds don't mean much.
I don't know if it relates but I use GM fuel filters and I let the dealer change it. I learned on an LLY 5500 that I was using NAPA fuel filters on. Lost an injector, and washed a cylinder. Related? I don't know but I have heard from engine builders when I was looking to rebuild it, that it is best to stay with the GM fuel filters. I think having documented fuel filter changes with OEM filters matters on issues like this. Just a suggestion regardless if its a GM CP4 or another OEM.
http://castboolits.gunloads.com/archive/index.php/t-253772.html
https://www.duramaxforum.com/forum/06-07-lbz-lly-duramax-powertrain/131377-2006-c5500-jayco-seneca-mh-fan-explodes-taking-out-radiator.html
โJun-02-2019 09:09 PM
โJun-02-2019 07:09 PM
โJun-02-2019 06:20 PM
โJun-02-2019 06:10 PM
Halmfamily wrote:
There is a new upgrade on the market for Duramax that will let you change the CP4 pump to a CP3. The article was in Trailer Life magazine, one of the last two issues. Might be worth checking out if have to come out of pocket
โJun-01-2019 12:37 AM
โMay-31-2019 08:54 PM
โMay-31-2019 06:29 PM
Grit dog wrote:
Until the OP provides more info, weโre all just speculating at the cause, warranty , miles, etc.
could have 300k on it and be so far out of warranty or it could be a crappy dealer hosing him on warranty or it could be bad fuel and a call to the insurance company is in order.
โMay-31-2019 05:57 PM
โMay-31-2019 06:09 AM
Bigfoot affair wrote:reelcamper1 wrote:
Had a catastrophic fuel pump failure in our 2015 GMC Sierra Denali 2500HD Diesel......lost all power steering, brakes, etc. Dealer wants $12000 to repair! When the pump fails, metal shavings go thru entire fuel line, etc
After researching online, GM knew about this (CP4 fuel pump) issue before we bought our new truck in 2015!
We were lucky this happened at our seasonal campground & not while towing our 5th wheel in traffic.
Posting this as a warning to all of you with a GM diesel 2011-2016
Jeep/Ram eco diesel
Titan with Cummins
โMay-31-2019 06:02 AM
