โJan-01-2018 12:54 PM
โJan-02-2018 07:26 PM
โJan-02-2018 05:26 PM
โJan-02-2018 05:13 PM
โJan-02-2018 02:09 PM
โJan-02-2018 02:03 PM
GordonThree wrote:GWolfe wrote:
My friends have an 07 or 08 Ram 2500 Cummins that has a "light load" button that allows them to run lowers pressure in their tires with out the computer nagging them. Are the newer ones not like this?
Never heard of that. Maybe an upfitter or aftermarket option?
โJan-02-2018 12:41 PM
โJan-02-2018 11:52 AM
IdaD wrote:
From the factory the coils are rated to carry 500 lbs less than the 3500's leafs. Not really a big deal. They do ride and handle very nicely for a heavy duty truck. The lower payload numbers on the bulk of the 2500s has everything to do with the class 2 max GVWR, except on a few of the base 5.7 trucks equipped with 17" wheels and tires.
GWolfe, there is no light load button anymore. I don't see the TPMS as much of a negative. I run at 65/80 during towing season and 65/65 during the offseason. I guess a quarter inch indicator light on the display bugs some more than it bugs me.
โJan-02-2018 11:48 AM
โJan-02-2018 11:46 AM
โJan-02-2018 11:31 AM
โJan-02-2018 11:21 AM
โJan-02-2018 08:16 AM
โJan-02-2018 07:38 AM
โJan-02-2018 07:11 AM
spoon059 wrote:Second Chance wrote:
The new Ram 2500s can have as little as 2,2010 lbs. payload rating depending on configuration according to the Ram web site. I would guess that coil springs have something to do with that. The 3/4 offerings from "the other two" usually have around 3,000 lbs. payload.
The very low payload 2500's are either 5.7 engine with an 8800 lbs GVWR (not even sure if they are offered in 2018) or the Power Wagon models which are designed as off-road vehicles, not tow vehicles and have a softer and taller suspension. Unless you get the smaller motor or the Power Wagon, a 6.4 Hemi Crew Cab should have about 3300 lbs payload before options. That puts it right in line with GM and Ford.
The coils are surprisingly compliant and I don't see any real downfall to them. They keep the rear end planted across highway joints, where my older leaf spring pickup would get a little jittery. They are rated for 6500 lbs, just a little shy of the 3500's leaf springs.
โJan-01-2018 10:25 PM
Grit dog wrote:
The 2 downsides I see with a 2500 ram is the above issue (for me, with a TC) and the stupid tpms thresholds which are now infinitely more difficult to adjust.
