Sep-29-2015 01:57 AM
Sep-29-2015 07:31 AM
Sep-29-2015 07:30 AM
It would be ridiculous to get an inadequate truck for the job over these minor considerations.
The statement about dually brackets is a total myth. Just plain ignorant and stupid. Dually brackets lock into position with very coarse square teeth that are held in place by the weight of the camper. They're not going anywhere. It's no more dangerous to camp on jacks with dually brackets than without. If the camper falls over, you had bigger problems to begin with.
Yes, the truck is wider. So what? A good driver can park a dually anywhere a full size car will fit. If you don't feel comfortable, just park farther out. A little extra walking will do you good.
Traction on snow and ice can be an issue. In addition to the PSI issue mentioned above, an SRW's front wheels clear a path for the rear wheels to be down on a better traction surface. A DRW's front and rear wheels do not line up, so each wheel is up on top of the mud/snow, cutting its own path. Two ruts vs. six ruts.
The traction is the only legit problem in this discussion, but it is only an issue in extreme conditions, and it can be overcome with simple dead weight in the bed of the truck.
Sep-29-2015 07:27 AM
bobbolotune wrote:
Now someone told me, don't get a dually. And this wasn't just anyone. It someone with extensive truck camper industry experience. What he said:
They are a problem for fitting into parking spaces. This one I already knew and accepted.
Duallys are terrible on snow and ice. This I didn't know. I would assume with 4 rather than 2 tires on the ground that a dually would be that much better for snow and ice. Not so? Although I didn't tell him that I am planning on a 4x4 dually, and possibly that makes a difference.
bobbolotune wrote:
Then the big one. You shouldn't camp in a truck camper with dually extension brackets. The extension is a hinge that swings in and out. It isn't stable. It is ok for storing the camper off the truck, but you shouldn't camp off the truck in a camper with dually brackets.
I hope those with actual experience can please express an opinion about these topics. About the snow / ice issue, and especially about the dually brackets.
Specifically the camper being discussed uses Happijac jacks and dually brackets. Possibly those are not the best jacks?
Sep-29-2015 07:25 AM
Sep-29-2015 07:01 AM
Sep-29-2015 05:45 AM
Sep-29-2015 05:30 AM
Sep-29-2015 04:50 AM
Sep-29-2015 03:52 AM
Sep-29-2015 03:33 AM
Sep-29-2015 03:18 AM
Sep-29-2015 03:10 AM
Sep-29-2015 02:54 AM
