Blowing out water lines?
D_and_A_plus_6
We camping over Easter for the First trip of the season. Went to Arrowhead County Park in Neola Iowa and had a great weekend. When we got ready to leave and not knowing when we were going to go camping again, I blow out my water lines and drained my hot water heater, so the water wouldn't get stale or old setting in the lines.
Was this over kill, or do several of you do the same thing. At the time, with baseball/softball season approaching, it may be at least Father's Day weekend before we'd be out again.
Thanks for any inputs or other ideas.
14 REPLIES 14
SoundGuy
First a disclaimer as this is only my opinion and not intended to get anyone's shorts in a knot if they don't agree. :W
If one finds that emptying the water heater tank (6 to 10 gals) and a partially filled fresh water holding tank (say 10 to 15 gals) before towing is enough to make a difference when towing then IMO they're already towing way to close (or perhaps over) the limits of their vehicle. After all, we're talking perhaps 200 lbs of water and even for a trailer weighing a mere 4000 lbs that 200 lbs only represents 5% of the trailer's overall gross weight. In my case, I do tow within capacity of the vehicle and after an initial sanitizing in the spring (which I'm about to do today) I fill the water heater tank, half fill the fresh water tank, pressurize the trailer's water system, and leave it that way for the entire season, only fully purging it of water during my winterizing process. IMO there's just no reason not to and doing so allows us to use the system anywhere we want at any time, whether actually camping or not.
2012 Silverado 1500 Crew Cab
GrandpaKip
When breaking camp, I open the low point drains and faucets. I have a butterfly valve on the WH that I open so that it drains. When we get home, the lines are empty and the WH has sloshed out the calcification in the bottom of the tank, or at least some of it.
I only blow out the lines for freezing temps.
Never have worried about bacteria, mold, etc. in the lines. I do sanitize the FW tank before use, if it's been sitting for a couple weeks or so.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
LVJJJ
I always drain the hot water tank before travelling, towing with a 50 year old '65 Chevy van is very weight sensitive. Plus, 6 gallons of water adds 50 pounds of weight to haul around. Actually, all water tanks are empty when we tow.
Always winterize by blowing out system, quicker, easier, cheaper than antifreeze that makes water taste bad in the spring. done this since late '80's, never had a busted water line
1994 GMC Suburban K1500
2005 Trail Cruiser TC26QBC
1965 CHEVY VAN, 292 "Big Block 6" (will still tow)
2008 HHR
L(Larry)V(Vicki)J(Jennifer)J(Jesse)J(Jason)
skipnchar
Use treated city water and leave it in. I always handle it almost the exact opposite from how you describe. When I leave too go home I make sure my water system is completely filled for storage. Since you CANNOT dry out your entire system it's much better to have treated water instead of a warm, damp empty space in which bacteria, mould etc. can find a home.
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
93Cobra2771
Once season starts, I never drain. However, we rarely if ever drink from the faucet. Cleaning and showers only...
Richard White
2011 F150 Ecoboost SCREW 145" 4x4
Firestone Ride-Rite Air Springs/Air Lift Wireless Controller
2006 Sportsmen by KZ 2604P (30')
Hensley Arrow
RoyB
We only blow-out our water lines when camping in very low temperatures. The BLOW OUT method is very quick for us us if we feel like the low temps may do some harm to us over night. We can then re-fill the tanks the next day and continue on...
We also very seldom use our fresh water for consumption. We always have a couple of same brand bottled water with us to get the same great bean coffee taste when we grind and brew our own fresh made bean coffee all the time. We use this water for drinking and cooking with.
The campground and fresh water tanks are only used for washing dishes, taking showers, and flushing the pots etc... As said in a similar post up the thread here I also may get to squirt a squirrel too with the camp ground water haha...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
RoyB
Roy - Carolyn
RJCorazza
I suspect there is actually more chance for bacterial growth in drained untreated lines (moisture and air). I do not let my water system sit unused without chlorinated water in the tank and lines. You did not specify if the water in the system is chlorinated, but if treated IMHO it wouldn't matter if the lines were drained or not.
Since you are concerned with water quality and safety as opposed to freezing, I will add that I sanitize each spring at 50ppm for several hours, and after flushing, treat the tank water with 2-4ppm chlorine for drinking the rest of the season. If not used for more than 30 days or so I will drain and refill the system with fresh treated water.
Lantley
I never drain my water heater or piping once the season starts.
I am using chlorinated city water and I go out every 2 weeks or so.
I see it as additional work. However if you are on a well or have the RV sitting idle for long periods. Draining maybe beneficial
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
BakFlip,RVLock,5500 Onan LP,Prog.50A surge,Hughes autoformer
Porta Bote 8.0 Nissan,Sailun S637
Correct Trax,Splendide
heckufaguy
I drain in the fall, hit the bypass for the water heater, pull the plug. (Mine does not have an electric element). Then I blow out the lines and suck in a little antifreeze. Fill the traps too. When it's finally above freezing for a week here all week. (So far, no joy) I Sanitize and fill the system. I don't drain it again until fall. I keep it full of water in the yard, as a power outage or two have caught me in the past and at least I can still have water/shower. (On a well). I don't travel with that water typically. (Weight)
I don't think you harmed anything... just a lot of extra work.
colliehauler
I will offer a different opinion. Do remember science class an the petri dish growing bacteria? Introduction of air (with bacteria) in a moist environment is not a good thing. I would sanitize the system before use if you drink the water.
That said I always drain my water heater when I'm not going to use it for a while. Just make sure power is off or element is toast.
bob213
Just make sure your water heater is off(or you refill water heater) before you plug into electric again. Empty tank means instant element burnout.
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
Old-Biscuit
No harm draining.
mtofell1
I only blow mine out when there is freezing temperatures. There is no harm to leaving the lines pressurized. If you want to relieve some pressure just turn off the water pump (with city water not attached of course) then open each faucet for a second. If you're worried about contamination just let the water run for 10 seconds or so when you use the trailer after and extended period of sitting. IMO there's really no harm to letting it sit. The materials are basically the same stuff as in a house and people let that sit for years sometimes and it does fine.
