Electric drill for lift jacks
ronday
Who makes a battery powered drill that will lift the truck camper? I have several drills but none have the torque to lift the camper. Also I know not to use a hammer drill as that will ruin the right angle gears. Thanks. Ron
2008 Chevy 2500HD D/A, Crewcab SB, Pullrite superglide
2011 Big Country BC 3250TS 33ft 5ver
2005 Fleetwood 26ft 5ver
2005 Sun Lite Truck Camper
Ron - 29 yrs HS Tech Teacher (ret) 24 yrs USN/USNR Chief (ret)
Sheila - 29 yrs HS Home and Careers Teacher (ret)
26 REPLIES 26
mkirsch
Nomad II
Nomad II
I use a Ryobi 18V for the tedious "no load" cranking.
The drill grunts and strains too much for my taste once there's weight on the jacks.
Besides, I can't ensure the camper is being raised evenly if I'm using the drill. It's a 13-year-old Palomino, and doesn't like being racked much. It creaks and groans and pops the door open.
Once the feet have touched down, I work my way around the camper, cranking 10 turns at each jack to keep it fairly level. It only takes 3 trips around the camper to get it completely raised.
NMace
My 18v Ryobi does fine. I suspect the gear ration is a factor, my jacks are Atwood.
2002 Silverado 6L 1500 HD 4x4 Crew Cab
2011 Puma 295 KBHSS
FreeLanceing
if you want to get serious about it try the dewalt 20v lithium ion. You could probably rotate the truck tires after unloading with power to spare. I just crank mine by hand, nice little work out and free.
KD4UPL
Most anything 18v and above should do it. Milwaukee, DeWalt, Bosch, Makita, etc.
You will need to have charged batteries to do it.
If someone has a drill they rarely use and the batteries just sit a lot they will loose their charge overtime. If you just pull them out one weekend to raise the camper likely they will both be less than full.
RWDIII
this is what I use,came with 2 batts.
when I store the camper in the garage,used both batts but the first batt wasn't fully charged.
OLD 2006 F150 4wd 7200gvw,Lt275-65-18,Scan Guage,Garmin,flowmaster,load levelers,Firestone work rites Bronco 800
NEW 2015 F250 Scab 4wd 10000 gvw, 6.2 Scan guage,Garmin,work rites,3200 lb load,1800lb Palomino Backpack SS1200
loulou57
My hubby uses an 18v cordless Dewalt, works great. It only takes around 15 minutes to recharge.
realter
Its really not that hard to do it manually!! I have no electricity where I store mine, and the battery is usually low after several weeks of storage.
handye9
I too, have tried several (Ryobi and Dewalt included) cordless drills, with little success. Seems like the drills with enough torque, don't have batteries that will last through a loading evolution. You're in good shape as long as you have a lot of batteries charged up.
I purchased a heavy duty corded drill, and keep it in the TC.
18 Nissan Titan XD
12 Flagstaff 831FKBSS
Wife and I
Retired Navy Master Chief (retired since 1995)
donn0128
I use either my Craftsman or Hitachi 18 volt drill diver. Both perform perfectly.
valhalla360
Nomad III
Nomad III
A small step up from the $30 drills they have versions a switch to drop the gear ratio. In low gear with a charged battery, they will twist your arm off.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
gscudder
I used my 18 volt Ryodi impact driver for years, no problems on either the scissors jacks on my RV or the lift jacks on several different truck-campers.
Retire Abrams Master Gunner (Army)
