F150 goodbye, hello F250
Sportsmen
Just traded my 07 F150 for a 2016 F250 crew cab with a 6.2L gas. My first 3/4 ton PU. Haven't towed with it yet, but the F250 feels like a lot more truck to me.
12,500 lb tow
3200 lb payload
F150 was a good truck for sure, but always felt a little light when towing our 27' bunkhouse at 6800 lbs.
Towing report coming in near future !
2016 Jayco Jay Flight 27BHS 6210 empty, 8200 GVW
2016 F250 CC 6.2L(gas) 3:73 diff (3157lb. payload)
20 REPLIES 20
FishOnOne
Lynnmor wrote:
FishOnOne wrote:
A 6.2 weighs ~600 lbs and a 6.7PSD weighs 990lbs dry.
Does that 6.7 figure also include an additional cooling system, heavier drive train and an exhaust system the size on a cruise missile?
Both weight's are the dry engine weights only and exclude accessories and exhaust system.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
harmanrk
Correct, moving from the 6.2 to the 6.7 costs about 800-900 off the payload. Most of that is the lump of CGI, but as was said, Radiators, Inter-coolers, Exhaust, Heavier Transmission (6R140 vs 6R100) make up part of it as well.
2017 Ford F250 CC-SB SRW PSD
2013 Solaire 190x
Lynnmor
FishOnOne
rhagfo wrote:
spoon059 wrote:
2 many 2 wrote:
I looked at several other brand trucks and the Ford Diesel trucks too and I could not find a payload over 3K like the 250 gasser. The 250 was well over a 1000 pounds better in payload than anything else I looked at.
The diesel engine weighs about 800 lbs more than a gas engine. 3/4 ton trucks are arbitrarily limited to 10,000 lbs to stay in that 2B class. A gas 3/4 ton truck with 10,000 lbs gvwr will ALWAYS have more payload than a heavier diesel. Its simple math.
If you want diesel and more payload, get a 1 ton. Essentially the same truck with no arbitrary GVWR.
So a 6.2 only weighs 300#?? Cummins the heaviest of the diesels only weighs 1,100#.
rhagfo
73guna
Going from a 1/2 ton to a 3/4 ton is so much less driver fatigue while towing.
2007 Chevy Silverado Crewcab Duramax.
2016 Wildwood 31qbts.
jerem0621
Congrats OP!!!!
You will love it!
Thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
It’s Kind of Fun to do the Impossible
~Walt Disney~
NWnative
I did the same thing a few months back. Doubled my payload over the F150. Congrats!
2019 Ford F250 Lariat CrewCab Short Bed 4x4 - 6.2 Gas w/4.30 Axle
2016 Airstream Flying Cloud 30RB / Blue Ox Sway Pro / Rock Tamers
2021 Mazda CX-9 Signature AWD
2Rad4U
Congrats! Good move
Chris
2005 Rockwood 2516G (sold)
2005 Max-Lite 24RS (sold)
2019 Rockwood 2608BS (sold)
2020 Grand Design 337RLS
2018 Chevy 2500HD
BenK
Lost to many is 'duty cycle' and warranty there of...vs lower ratings of the exact same..
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
2edgesword
Congrats on the new ride. We moved up from a 2007 Silverado 1500, 4.6L, 2WD pulling a 4,500 pound trailer to a 2012 F-250 regular cab, 6.2L, 3.73, 4,000 lbs payload pulling an 8,800 pound trailer. Pulls the trailer with easy but is a rougher ride due to the stiffer suspension.
harmanrk
Sometimes still with an arbitrary GVWR, just a higher one. 😉
2013 Solaire 190x
spoon059
2015 Ram CTD
2015 Jayco 29QBS
danrclem
You're going to like everything except the gas mileage. I know, I have one.
I think you'll really see the difference when towing. The F250 should handle your camper with ease.
