Jul-02-2018 03:18 PM
Jul-30-2018 04:57 PM
Jul-30-2018 05:48 AM
Jul-28-2018 06:23 PM
Jul-28-2018 05:57 PM
Jul-28-2018 02:25 PM
Cummins12V98 wrote:
"I'll be calling the dealer first thing in the am for sure."
What do you think the Dealer will say? Sounds like poor quality right from the RV Factory. Do your self a favor and swap out to a Kodiak Disk conversion kit, you WILL thank me!!!
Jul-28-2018 01:38 PM
Jul-28-2018 01:16 PM
Jul-06-2018 01:22 PM
Jul-06-2018 11:41 AM
Lynnmor wrote:Parallel tapped into the connector/plug on the ITBC (located behind the lower dash--below right of the steering column) and measured the braking output voltage with my VM. Been a few years so I can't remember the color code for the OEM ITBC wire with the braking voltage. Most aftermarket units use the blue wire.otrfun wrote:How, and where were you measuring the voltage at highway speeds?
Our '16 Ram Cummins SRW came with the OEM ITBC from the factory. With it set to max (10), it will only produce approx. 8 volts of braking voltage (at all speeds). For trailers that only needed 8 volts or less to brake safely, then all was good. If the trailer needed 8 - 12 volts then we were out of luck.
Jul-06-2018 10:01 AM
Jul-06-2018 09:25 AM
Jul-06-2018 08:26 AM
Jul-06-2018 06:21 AM
Huntindog wrote:mkirsch wrote:The OP doesn't have a P3..... Yet. He is considering that as a solution.
If the P3 works and the IBC doesn't, there's no sense in pulling your trailer brakes apart. You've already proven where the issue lies.
To The OP:
Check out your brakes first . Most everyone loves their IBCs... That goes for Ford, GM, and Ram... It is unlikely that you have had two Rams in a row with faulty IBCs... It is much more likely that there is a brake problem. Grease being a primary culprit.
A lot of trailers IMO, are under braked in the first place... So if they are not functioning at peak performance, they are terrible.
Jul-06-2018 02:15 AM
