โSep-06-2015 05:34 PM
โSep-13-2015 06:46 PM
โSep-13-2015 04:43 AM
โSep-12-2015 11:30 PM
โSep-08-2015 01:03 PM
โSep-08-2015 12:38 PM
โSep-07-2015 12:00 PM
โSep-07-2015 11:48 AM
54suds wrote:
I have repaired the same problem using Loctite epoxy instant mix self mixing applicator and fluted dowels and drilling a new pilot hole in the dowel
is you BF a 1500 series?
you can also try using a much larger diameter lag bolts . try it in one of the middle holes to check for how well it holdsBedlam wrote:
Start by filling the holes with tooth picks dipped in epoxy. Once set, use the next diameter larger screw. If you have access from the inside, you came add an internal backing plate and use bolts instead.
โSep-07-2015 11:40 AM
โSep-07-2015 11:33 AM
โSep-07-2015 10:38 AM
โSep-07-2015 10:33 AM
โSep-07-2015 10:02 AM
โSep-07-2015 06:06 AM
โSep-07-2015 05:47 AM
