โFeb-28-2010 07:12 PM
โJun-04-2012 11:59 AM
pyro383 wrote:
Is anyone having an issue with the outside kitchen door where the screws are pulling out of the clip that holds the piston assembly.
I am trying to come up with a repair so that the screws hold or add a plate to disperse the tension.
โJun-04-2012 10:56 AM
I sure did. The problem is there is too much of the load concentrated in that one area where the gas strut hinge mounts to the door. That gas strut is VERY strong. What I did was made a bigger (wider footprint) piece of metal and mounted that to my door where the original hinge mounted. Then I mounted the original hinge to that. The idea is to spread the load of the hinge to a larger area.
Do you know if there is any support bars within the door itself where you added the additional screws? Can you post a pic when possible?
Mine was on the left side when facing the kitchen.
โJun-04-2012 10:35 AM
โJun-04-2012 10:26 AM
โJun-04-2012 10:15 AM
โJun-04-2012 09:49 AM
โJun-04-2012 09:38 AM
jasoncw wrote:
I got up on my roof for the first time this year to give it a good cleaning, and I noticed that I have a nice 8" long crack in the caulk on the front seam where the roof meets the fiberglass front cap. So I guess I am going to replace at least this one full seam with some Eternabond. Does anyone have any tips to remove the old caulk without damaging the rubber roof?
Thanks,
Jason
โJun-04-2012 09:24 AM
โJun-04-2012 08:51 AM
โJun-04-2012 08:22 AM
โMay-31-2012 09:14 AM
โMay-25-2012 02:39 PM
โMay-24-2012 03:10 AM
โMay-23-2012 06:49 PM
baunno wrote:
We used our 2012 Bullet last April and noticed that the condensation of the frig is not draining. It fills up with water under the fruit and vegitable bins and eventually over flows onto the floor. I blew through the drain hose outside and it passed air through the system. Has anybody else had this problem?
โMay-23-2012 06:31 PM
