stab jack lube
gserve
What do you use to lube the stablelizer jacks on your rig?
15 REPLIES 15
prichardson
Paraffin works well. Take an old candle and rub it along the screw part.
dee74
Anyone use graphite spray?
dclark1946
Regular WD 40 a couple times a year. No issues with dirt attraction.
Dick
Dick & Karen
Richardson,TX
2017 KZ Spree 263RKS
09 F250 V10
69_Avion
pfidahospud wrote:
Silicone spray. Doesn't attract dust. Seems to last well.
That is exactly what I use. You don't want anything that can attract dirt.
Ford F-350 4x4 Diesel
1988 Avion Triple Axle Trailer
1969 Avion C-11 Camper
Bigbird65
When we first got our trailer I made the mistake of using wheel bearing grease on the lead screws of the manual stabilizer jacks. They turned so easily that under pressure they would unwind or turn back several turns when the pressure was relieved. The fix was to remove the grease with solvent and spray on a lite coat of WD40 to prevent any chance of rusting.
2017 RAM 1500 Quad Cab 5.7L Hemi, 8 speed 3.21
2018 Winnebago Minnie 2250DS
coolbreeze01
WD-40ยฎ SPECIALISTยฎ WATER RESISTANT SILICONE LUBRICANT
2014 Sandsport 26FBSL
Winged_One
Dry lube.
2013 F350 6.7 DRW SC Lariat
2011 Brookstone 354TS
Swivelwheel 58DW
1993 GL1500SE
Yamaha 3000ISEB
Community Alumni
Not applicable
Another vote for motorcycle chain wax. It's dry, stays where you put it, and it repels everything.
Doug33
Use WD40 a few times a year, and it doesn't seem to attract dirt and dust that much.
2014 Keystone Bullet 281BHS
2002 Chevy Avalanche 5.3L 4x4
Equalizer hitch
Nights spent camping in 2015: 25
Next trip: mid-April 2016?
pfidahospud
DBH_MI
Motorcycle chain wax.
ScottG
They come with a heavy light colored grease on them - kinda looks like vasoline.
SoundGuy
The Solution by Krown, wonderful stuff! Far superior to WD40 and won't attract dirt as does grease. :B
2012 Silverado 1500 Crew Cab
djcjc
WD 40
