Using silicone on a rubber roof?
slacker_cruster
In an emergency can I get by with some clear or white silicone for sealing cracks on a rubber roof?
13 REPLIES 13
slacker_cruster
This pretty much answered my questions. Great rubber roof resource.
http://www.bestmaterials.com/RV_roof_repair_info.aspx?gclid=CjwKEAjw2qzHBRChloWxgoXDpyASJAB01Io0ftc-lExChAX5UICFxHvk9J8IHzcLYyA2HuIgI4_YFxoCUlrw_wcB
Old-Biscuit
slacker cruster wrote:
Thanks for the help. Amazing how one caulk wont sub for another. I figured almost anything would be OK. I will check out the Eternabond and BU caulk tube option.
Hi Old Biscuit! Yes, have not had to bother the group for many years. My Northstar TC has been fine for all this time. Now it is starting to age and had some problems / questions. I told you I would be gone once my rig was in ship shape and I was good to my word. Thanks for remembering me!
You are WELCOME! :B :B
AnEv942
Bottom line is no, even in an emergency.
If your going to carry 'Just in case', get something else.
If its something (the emergency) that has to be done now, use just about anything else. Or tarp if parked.
Using silicone as an temporary emergency fix only creates a permanent problem.
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page http://www.ourelkhorn.itgo.com
slacker_cruster
Old-Biscuit
Sure why not.....it's an emergency
Course this answer is ONLY for slacker cruster who has been around since 2011 and has a thing for asking 'questionable questions'
2oldman
Bumpyroad wrote:
in an emergency use that emergency tube of decent caulk you carry.
bumpy
x2
ScottG
No, not even in an emergency.
If your concerned about damage while on a trip then get some Eternabond tape to carry. They also make a square patch - which is what we have.
Bumpy has a good idea in carrying a tube of Dicor but I've found an unopened tube dries up in a year or two so you'd need to replace it occasionally.
pianotuna
Nomad III
Nomad III
Don't use silicone.
Regards, Don
Silicone is for bathtubs.
It has no place for any exterior sealing application.
Silicone will destroy your chances of ever properly sealing the area.
As mentioned, carry the emergency tube of appropriate sealant.
I carry a tube of Dicor at all times.
2007 GMC 3500 dually ext. cab 4X4 LBZ Dmax/Allison - 2007 Pacific Coachworks Tango 306RLSS
RV Rebuild Website - Site launched Aug 22, 2021 - www.rv-rebuild.com
Bumpyroad
bumpy
Chris_Bryant
Once you use silicone, nothing else will stick, so- no. Butyl gutter seal is easily available and compatible.
-- Chris Bryant
donn0128
Only if you want to replace the entire roof!
Silicone is the absolute worst product to use next to gasoline on a roof.
towpro
I would stick with dicore. If supply is a problem you can order it of Amazon for fast shipping.
2022 Ford F150
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Sold Forest River Forester 2401R Mercedes Benz. when campsites went from $90 to $190 per night.
